Thermal Wrap good enough?
Old Feb 14, 2005 | 03:54 PM
  #26
fipracing_com's Avatar
Default Re: (1SlowSi)
No only wrap the Intercooler piping, that is if the wastegate exhause will hit it. Other than that you should be good to go.
Old Feb 14, 2005 | 09:54 PM
  #27
1SlowSi's Avatar
Default Re: (fipracing_com)
i bought the wrong wrap. i got the white fiberglass kinda wrap to wrap the exhaust. I used it on my ac lines, and oil drain line. Ohh, and part of the dump tube near the ac lines. Its good for 2000 degrees so it should be okay right?
Also, that dump is exactly a foot away from my iC piping. You say wrap it too? I mine as well, but im gonna do it with the silver reflecto wrap.
Old Feb 15, 2005 | 10:23 AM
  #28
fjt's Avatar
fjt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">i bought the wrong wrap. i got the white fiberglass kinda wrap to wrap the exhaust. I used it on my ac lines, and oil drain line. Ohh, and part of the dump tube near the ac lines. Its good for 2000 degrees so it should be okay right?
Also, that dump is exactly a foot away from my iC piping. You say wrap it too? I mine as well, but im gonna do it with the silver reflecto wrap.</TD></TR></TABLE>
You shouldnt use that wrap for the Oil lines or A/C lines..The wrap you bought is to prevent Heat escape form the pipes(I.E. your Exhaust,Dumptube,Manifold) not to block heat.. Basically youre making the oil line retain more heat inside thus heating the oil even more..you dont want to heat it, you want to cool it.
you need the "foil type" wrap for your AC lines or Intercooler pipes.
Old Feb 15, 2005 | 03:04 PM
  #29
1SlowSi's Avatar
Default Re: (fjt)
But for temporary use.. it will protect them correct? I already orderd the right stuff.
Old Feb 16, 2005 | 03:54 AM
  #30
fjt's Avatar
fjt
yeah for temporary use i guess its ok
ls1formula98
Apr 14, 2015 06:05 PM
BodyKits NW
Welding / Fabrication
Aug 13, 2007 07:31 AM
2kjettaguy
Dec 1, 2005 12:35 AM
PM-Performance
Oct 28, 2002 05:31 AM
