is this true about dump tubes?
Old Oct 13, 2002 | 04:14 PM
PM-Performance's Avatar
Default is this true about dump tubes?
does it really make you lose hp from routing the dumptube back into the exhaust with the downpipe?
is it better to just have an aope atmosphere dump tube?
thanks./
Old Oct 13, 2002 | 04:19 PM
MiraiZ's Avatar
Default Re: is this true about dump tubes? (itr206)
Yeah...you can lose up to about 15% of the total HP by using a dump tube...open WG is best if you want optimum power...personally, I would sacrafice the power (on a daily driver) for a quieter ride...
[Modified by MiraiZ, 1:08 PM 10/14/2002]
Old Oct 13, 2002 | 04:35 PM
sutrusu's Avatar
Default Re: is this true about dump tubes? (MiraiZ)
you can get a dumptube that doesn't route into the exhaust
but if you dont run a dumptube, you risk blowing your a/c lines... someone posted here a few weeks ago that they blew their ac lines... so no more ac for them
Old Oct 13, 2002 | 04:38 PM
Ri5e's Avatar
Default Re: is this true about dump tubes? (sutrusu)
You can get a 90 degree elbo welded with flanges on both ends to make the waste gate shooting down. But it still won't be as "quiet" as closed loop.
Old Oct 13, 2002 | 04:44 PM
Default Re: is this true about dump tubes? (4 Stroke)
i dont have ac anyhow
yea i was gonna just run it stright down via dump tube if i didnt make it closed loop / i wouldnt want to just keep the bottom of the wastegate open / like to keep things neat.
Old Oct 13, 2002 | 05:21 PM
ezark's Avatar
just route it pointing towards the ground
Old Oct 13, 2002 | 06:49 PM
Flamenco-T's Avatar
Default Re: is this true about dump tubes? (gsR-T mode)
it depends on where you dumped the tube in the dopwnpipe....
I believe if you dump it 25-30" from the turbine, you lose very very minimal HP versus, closer spot from the turbine..
stan
Old Oct 13, 2002 | 08:36 PM
mos's Avatar
mos
Default Re: is this true about dump tubes? (Flamenco-NA)
Damn 25 inches is far. I think like 14 is enough. But ya the furthur the better, I guess.
Old Oct 13, 2002 | 08:45 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: is this true about dump tubes? (mos)
per corky bell, it is 18"
stan
Old Oct 13, 2002 | 08:46 PM
dustin's Avatar
On the dyno, I didn't lose any power one way or the other... I had 3" exhaust/dp though.
Old Oct 13, 2002 | 08:49 PM
Flamenco-T's Avatar
Default Re: is this true about dump tubes? (90crxsi)
stan
yeah, that sounds about right...I knew for sure there is a certain distance to have a minimal lose off power, but again, like dustin's for example, some don;t lose power at all...
Old Oct 13, 2002 | 09:02 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
you're more prone to boost creep with a closed loop too. Unless the transition into the dp is at a shallow angle, you'll probably experience some boost creep as the wg exhaust gases have to push against the fast flow of dp gases.
Old Oct 26, 2002 | 06:36 AM
EG6owner-T's Avatar
Default Re: is this true about dump tubes? (PreIudeSI)
what if I'm running the revhard stage 2 kit? and use a flexpipe to connect to my existing exhaust? Will I lose power?
The exhaust is a 2 1/4" straight with a 3" muffler universal. LMK
I mean my car is pretty loud, but like to keep it cause of daily driver and cops will give me noise pollutions citation.
Old Oct 28, 2002 | 04:16 AM
EG6owner-T's Avatar
Default Re: is this true about dump tubes? (EG6owner)
Old Oct 28, 2002 | 05:24 AM
craesq's Avatar
It depends on whether your DP is a cause of too much backpressure. If you have a 3" DP, then I doubt there would be any increase in power going to open loop. However, FMAX has a 2 1/4" DP and they dynoed a Prelude turbo at 9psi and got 40 more HP when they went open loop!!! Go see their website http://www.f-max.com .
Also, remember, your car will only be louder when the wastegate is open. At that point, your exhaust should be really loud anyway and noise should not be a concern if you are flooring it. My car is closed loop, but I drove an open loop car and did not really notice much difference in noise.
But, make sure you have a long dump tube or else you will get black exhaust in your engine bay!
- Chris
P.S. I will be switching to open loop when I find a way to seal my FMAX downpipe.
Old Oct 28, 2002 | 05:31 AM
EG6owner-T's Avatar
Default Re: is this true about dump tubes? (craesq)
First off im not into the noise but more in the power, but like to keep the noise to a minimum, cause cops love to hate.
so did you feel a difference in open and close loop?
i will get the rev hard kit, its not on btw.
if there's no difference in noise then how can i keep my exhaust to low volume and still not lose any power.
JDMCIVIC919
May 24, 2012 09:53 AM
DelSolMarine
Oct 25, 2007 08:30 PM
BodyKits NW
Welding / Fabrication
Aug 13, 2007 07:31 AM
B18c1turboedEK
Aug 15, 2003 05:17 AM
whagkangmakulet
Nov 8, 2001 01:11 PM
