Testing turbo?
Old Oct 26, 2001 | 04:02 PM
Honda Hick's Avatar
Default Testing turbo?
I just bought a supposedly rebuilt t3/t4 turbo and now that i got it, it seems like there is a small bit of slop in the shaft. To try and test the seals and bearings I made a plate for the oil outlet side of the turbo and filled it up with oil. then I put about 50 lbs of pressure into the other end and turned the shaft. After about 5 minutes oil came oozinf out of the exhaust housing. Is this an effective way of testing to see if the turbo is good? Thanks
-Scott
Old Oct 27, 2001 | 09:49 AM
Honda Hick's Avatar
Default Re: Testing turbo?
anyone???
Old Oct 27, 2001 | 11:25 AM
Rexbo's Avatar
Default Re: Testing turbo? (Honda Hick)
Sounds like you've got some bad seals, as for the shaft play there should be a very very small amout less than 1/8 inch. Try this site it will better explain how to test for excessive shaft play http://home.istar.ca/~dvandit/faqs.htm
try this site as well http://www.specialstage.com/tech/dsm/dsmtech3.shtml
HamiltonRex
Jan 24, 2010 09:48 AM
brad98_teg
Apr 13, 2006 08:17 AM
turbotime
Mar 30, 2006 02:07 PM
huge230
Mar 27, 2006 03:35 PM
zojirushi
Nov 14, 2001 08:36 PM
