Techedge MAP input...?
Old Oct 19, 2006 | 11:18 AM
swlabhot's Avatar
Default Techedge MAP input...?
I am running a Techedge WB v1.5 with a P28 ecu (w/conversion adapter on board so no wire harness here). Trying to do some datalogging with their TEWBLOG v2 software. At the moment I have rpm input and AFR readouts but trying to also hook up the MAP input to it so I can read boost. The question is simply, do I use the std map output pin on the P28 or direct from the GM 3bar map sensor?
Old Oct 19, 2006 | 04:17 PM
drumking15's Avatar
i just spliced into the existing map singnal wire at the ecu....thats if you wired your 3bar up to the exist plug for the map sensor in the engine bay...which now thinkin about it would run if you didnt
Old Oct 19, 2006 | 11:43 PM
swlabhot's Avatar
Default Re: (drumking15)
I will give it a try when I get home tonite
carlos8
36
May 4, 2014 05:42 AM
chasmataz
Honda S2000
Sep 9, 2009 09:53 PM
Carbcivic
Mar 14, 2007 05:55 AM
aldong
Oct 8, 2006 06:15 PM
SpoolnByYou
Dec 24, 2005 02:35 PM
