techedge....
Old Apr 30, 2003 | 08:29 PM
  #76
Peter's Avatar
Default Instant messaging
I don't have instant messaging (nor will I ;-), so I can't reply to those couple of questions that have been asked.
Old Apr 30, 2003 | 09:05 PM
  #77
SiRkid's Avatar
Default Re: Instant messaging (Peter)
why did you not reply to my i/m and now you disabled them?
Old Apr 30, 2003 | 10:48 PM
  #78
servion's Avatar
Default Re: Spreadsheet calculation - Tech Edge WB output Voltage vs. AFR (Peter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peter &raquo;</TD></TR><TR><TD CLASS="quote">Try this out - it produces a graph for you to read off the values you need.
http://techedge.com.au/vehicle/wbo2/voutnew.xls
I don't have a page to explain it yet, but if you understand why you need this information, then you should know how to use it - I will try and get a page up ... You MUST know the input impedance of the device you're connecting the WB unit to in order to use the spreadsheet correctly.
Is the input impedence of my hondata-chippped ecu something I can measure myself or do I need to look it up off of a chart somewhere?
Old Apr 30, 2003 | 11:00 PM
  #79
Peter's Avatar
Default Re: Instant messaging (SiRkid)
When the IM box popped up it said I was not authorized! I couldn't reply. So I turned off that option in my profile - no idea if it worked?
Anyway, IM rather negates the usefulness of a true forum anyway.
Old Apr 30, 2003 | 11:04 PM
  #80
Peter's Avatar
Default Re: Spreadsheet calculation - Tech Edge WB output Voltage vs. AFR (servion)
I can't say about your ECU, but you can measure it yourself ... by reading off what the ECU tells you the measured voltage is while adjusting a resistance in series with a fixed voltage. When the ECU measures half the actual voltage, then the resistance you have is the input impedance to plug into the formula. Easy if you know what you're doing ;-)
Old May 1, 2003 | 04:23 AM
  #81
GruvyTune's Avatar
New User
has anyone taken the time to measure the input impedences of the honda ecus?
i dont want to take the time to do it if someone has already, otherwise i will.
Old May 1, 2003 | 04:28 AM
  #82
GOLDBERG's Avatar
peter..is there a minimumand maximum distance that wideband sensor should be from the turbo exhaust outlet????i have a bung 6-8 inches away but if thats too close i'll find a way to get another one farther away..wondering if too far is bad also or not??
Old May 2, 2003 | 01:43 PM
  #83
servion's Avatar
Default Re: Spreadsheet calculation - Tech Edge WB output Voltage vs. AFR (GruvyTune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune &raquo;</TD></TR><TR><TD CLASS="quote">has anyone taken the time to measure the input impedences of the honda ecus?
i dont want to take the time to do it if someone has already, otherwise i will.</TD></TR></TABLE>
I haven't seen any information on this.... (which of course doesn't mean it's not there... it just means that I haven't seen it). If you took the time to measure the impedences, I would be grateful. I doubt I would be the only one to use the info.
Old May 5, 2003 | 05:54 PM
  #84
servion's Avatar
Have you by chance decided to take on this task? If so, let us know... I'm very excited to use this new afr-&gt;voltage mapping
b16 matt
Sep 15, 2006 12:18 PM
Del$olB16A3
Mar 26, 2005 08:44 PM
11psiTurboSI
Sep 27, 2004 05:05 PM
nomotor
Jul 8, 2004 07:55 PM
Wrath of VTEC
Sep 15, 2003 06:58 PM
