how much boost on B18c1 with some internal work?
Old Jul 8, 2004 | 03:29 PM
nomotor's Avatar
Default how much boost on B18c1 with some internal work?
i got a B18C1 motor from my friend and i want to boost it. im going to add all new cams,valve train, IM, cam gears, and i want to know how much boost i can run if i just replace the RODS and PISTONS?
Old Jul 8, 2004 | 03:45 PM
MachAF's Avatar
Default Re: how much boost on B18c1 with some internal work? (nomotor)
350-400whp
Old Jul 8, 2004 | 03:50 PM
nomotor's Avatar
Default Re: how much boost on B18c1 with some internal work? (MachAF)
how much boost can i run? i know if the motor was all stock it would be about 7psi but since im replacing the pistons and rods i was wondering how much boost i can run?
Old Jul 8, 2004 | 03:51 PM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomotor &raquo;</TD></TR><TR><TD CLASS="quote">how much boost can i run? i know if the motor was all stock it would be about 7psi but since im replacing the pistons and rods i was wondering how much boost i can run?</TD></TR></TABLE>
350-400whp
Old Jul 8, 2004 | 04:20 PM
blackANESE's Avatar
I saw Geoff from Full-Race make over 500 with just pistons/rods
Old Jul 8, 2004 | 04:37 PM
MachAF's Avatar
Default Re: how much boost on B18c1 with some internal work? (blackANESE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackANESE &raquo;</TD></TR><TR><TD CLASS="quote">I saw Geoff from Full-Race make over 500 with just pistons/rods</TD></TR></TABLE>
Ya but then reliability comes into play. Stock sleeves won't be likeing that much power for very long.
Old Jul 8, 2004 | 06:25 PM
Turbo E's Avatar
the question is:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomotor &raquo;</TD></TR><TR><TD CLASS="quote">i got a B18C1 motor from my friend and i want to boost it. im going to add all new cams,valve train, IM, cam gears, and i want to know how much boost i can run if i just replace the RODS and PISTONS?</TD></TR></TABLE>
but the answer is:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">350-400whp</TD></TR></TABLE>
and alway will be
Old Jul 8, 2004 | 07:18 PM
-iLLuZioN-B18C1's Avatar
the noobs will never understand.
it all depends on your turbo and your setup.
the amount of boost you run is not important. it is just a number
if i have a small turbo i would be boosting a lot more than a bigger turbo
but it all depends on how much power your engine has to handle in the end, not
how much your turbo works.
Old Jul 8, 2004 | 07:22 PM
m R g S r's Avatar
Default Re: how much boost on B18c1 with some internal work? (-iLLuZioN-B18C1)
**** 300whp with pistons and rods. I wouldn't even bother and waist my money on them. 500whp stock sleeves, and thats deff. not the limit. Check out evohybrid's old setup, around 540whp stock sleeves.
^He didn't say reliable, he how much. And I'm not saying that a stock sleeved 500whp b series motor is not reliable
Old Jul 8, 2004 | 07:55 PM
TurboJesse
Guest
Posts: n/a
Ya but then reliability comes into play. Stock sleeves won't be likeing that much power for very long.</TD></TR></TABLE>
I belive he has more miles on that setup that any 500+whp Sleeved motor ive heard about...
I guess im just one that always has to go to extremes but if i did pistons/rods i would be dissapointed with anything less than 450whp.
Mechman456
Honda Civic (2006 - 2015)
Nov 6, 2007 11:25 AM
bboysake
Aug 11, 2006 03:02 PM
SpoolnByYou
Dec 19, 2005 02:28 PM
darkcrx
Apr 3, 2004 08:39 AM
808b18c1boosted
Dec 19, 2003 04:08 PM
