Tech: Another catch can question.....closed loop this time.
Old Jun 4, 2003 | 10:15 PM
93LSivic's Avatar
Default Tech: Another catch can question.....closed loop this time.
Ok, Im designing a closed loop catch can for my car. Gonna use a tradition style normally designed for open loop that uses the filter on top but gonna remove the filter and run a line going to the intake side on the compressor.
Now, Im sure that too much vacuum could be bad for a crank case with the amount of CFM a turbo would be pulling in. I was thinking of using a poppet style release valve similiar to Greddy's poppet bov. They are available to open in different levels of in/HG. Which one would I want to choose? I was thinking somewhere in the area of 5-7.
What are your guys opinions on this?
Old Jun 4, 2003 | 10:16 PM
tony1's Avatar
Default Re: Tech: Another catch can question.....closed loop this time. (93LSivic)
The more vacuum you can pull the better, but you still will have pressure in the crankcase. It takes a hell of a vacuum setup to keep vacuum in the crankcase under boost! Don't worry about the relief valve.
Old Jun 4, 2003 | 11:06 PM
lazerus's Avatar
Default Re: Tech: Another catch can question.....closed loop this time. (tony1)
only way you'll get a large vacuum in the crankcase, is by using a vacuum pump driven by a pulley. can be had off summit for like 300-400 dollars.
greasemonkee
Apr 28, 2007 11:25 PM
DaX
Jun 4, 2004 09:19 AM
b16hybridsol
Feb 23, 2004 06:54 PM
D21X
Oct 12, 2003 08:37 PM
Rice_Boy
Nov 21, 2001 12:53 PM
