t/f?
Old May 4, 2005 | 07:36 AM
coupon's Avatar
Default t/f?
was reading in some thread that if your car is orinally obd2 and you convert to to obd1 (with a conversion harness/ecu) for neptune/hondata. that your abs light is now your check engine light? my abs light was on the other day, so that was my cel? do i check it the same way as i would check a cel? and are the counts and # of times still mean the same thing?
Old May 4, 2005 | 07:39 AM
dornon13's Avatar
Default Re: t/f? (nlc)
i converted to obd1 from 2 ive never heard of that...and my CEL HAS been on so i doubt that is the case someone was probably trying to be funny in that thread.
ps. how would this be possible if you dont have abs
Old May 4, 2005 | 07:41 AM
coupon's Avatar
Default Re: t/f? (dornon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">i converted to obd1 from 2 ive never heard of that...and my CEL HAS been on so i doubt that is the case someone was probably trying to be funny in that thread.
ps. how would this be possible if you dont have abs</TD></TR></TABLE>
i have abs thought
Old May 4, 2005 | 09:59 AM
falcongsr's Avatar
What is this crap?
i had a strange ABS code when i was playing around with converting my car to obd1. i pulled the code and it was some wierd abs/airbag thing i forget. i cleared it (either disconnected battery or some procedure in the helms) and that was the end of it.
Old May 4, 2005 | 11:39 AM
dornon13's Avatar
Default Re: t/f? (falcongsr)
im not saying you dont have abs i am saying if you have an obd2 car without ABS (like me) and converted to OBD1 (like me) how would that work if what you are saying is true..the thread i am assuming you got this information from is most likely a wiring issue....dont worry about your ABS light unless its still on then figure out whats wrong with your ABS haha
Old May 4, 2005 | 02:14 PM
coupon's Avatar
up
Old May 4, 2005 | 02:21 PM
falcongsr's Avatar
What is this crap?
up to what? go fix it.
Tonyl507
Oct 8, 2009 05:56 PM
civic j
Jan 5, 2008 06:12 AM
831gsr
Jun 25, 2007 08:13 PM
typeR564
Feb 26, 2007 10:35 PM
SlammedCD7
Nov 9, 2004 03:56 AM
