Pulling a ABS Code on a 1998 OBD2???
Old Sep 8, 2009 | 06:25 PM
Tonyl507's Avatar
Default Pulling a ABS Code on a 1998 OBD2???
I can (and do) pull CEL codes by using the paper clip method under the passenger side dash, but accoring to THIS thread on team integra:
http://www.team-integra.net/sections...?ArticleID=493
the method will also work with ABS codes... Cant seem to get it to work. ABS light just stays solid.
Can anyone confirm or deny that the ABS codes can be checked with a OBD2 ecu using the paperclip method??
Old Sep 15, 2009 | 01:46 PM
Tonyl507's Avatar
Default Re: Pulling a ABS Code on a 1998 OBD2???
Bump for an annoying yellow light and no scanner
Old Sep 15, 2009 | 02:11 PM
JmurGSR98's Avatar
Yeah, I didn't know I had an ABS code until I had a CEL. Checked it with the paperclip and found out I had an ABS code: 16
So, yes. You can pull ABS codes using a paperclip. Its done the exact same way as checking a cel. My car is also a 98 OBD2.
Old Oct 8, 2009 | 05:56 PM
Tonyl507's Avatar
back from the dead...
still no luck with the paper clip. The CEL is not on, only the ABS light, paperclip does not seem to work...
I was thinking about buying a ODB2 scanner off ebay - seems to be ~$50.. will they pull ABS codes as well?
Wayne_Curr
Apr 13, 2006 03:07 PM
SlammedCD7
Nov 9, 2004 03:56 AM
2qwik2nv
Dec 1, 2002 01:42 PM
vti-R
Dec 26, 2001 08:59 AM
