switching wastegates (internal to external)
Old Mar 31, 2003 | 09:05 PM
wrXtian's Avatar
Default switching wastegates (internal to external)
just wondering if anyone has changed from a built in wastegate to a external wastegate?? is this hard.. or do you simply remove the arm and unplug the hose and connect that hose to a external wastegate on the manifold?? if possible does anyone have any pics of this process?
thanks
Old Mar 31, 2003 | 09:06 PM
b16ahybrid's Avatar
Default Re: switching wastegates (DA9onBoost)
just weld the flapper shut so it doesn't open or buy a plate to block the hole off. It's easy to do.....
Old Mar 31, 2003 | 09:12 PM
SlamMan's Avatar
you will need a new turbo manifold made for external wastegate, a new turbo with new downpipe and refit the charge pipe and an external wasetgate with a dumptube preferably routed back into your exhaust stream 18 inches after your turbo.
trav39562
Jan 4, 2009 01:33 PM
xfletcherxx
Jun 15, 2006 06:22 PM
abmerop18
Jan 27, 2005 08:05 AM
PolySquared
May 12, 2002 09:57 PM
