surging idle.....need help QUICK!!!
Old Jul 3, 2006 | 01:54 PM
  #26
themorphious's Avatar
Default Re: (w0ng_sta)
well, my car idles at about 800 rpms, and will drop about 100-150 rpm,s almost killing it, if i rev it up very minimal, and then let off the throttel, it will sometimes nearly die, and sometimes even die.....i dont know...im just going crazy!!!
Old Jul 4, 2006 | 02:48 PM
  #27
shortyz21's Avatar
Default Re: (themorphious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themorphious &raquo;</TD></TR><TR><TD CLASS="quote">well, my car idles at about 800 rpms, and will drop about 100-150 rpm,s almost killing it, if i rev it up very minimal, and then let off the throttel, it will sometimes nearly die, and sometimes even die.....i dont know...im just going crazy!!!</TD></TR></TABLE>
i got the exact same problem...
bump
Old Jul 4, 2006 | 09:38 PM
  #28
Default Re: surging idle.....need help QUICK!!! (themorphious)
bump for some more answers.........
Old Jul 5, 2006 | 10:40 AM
  #29
raresi99's Avatar
HAVE THE SAME DAMN PROBLEMS!!!!!!! BUMP let me know if you find out whats wrong
Old Jul 5, 2006 | 12:08 PM
  #30
porsche997dc2's Avatar
Default Re: surging idle.....need help QUICK!!! (raresi99)
I idle problem too. The idle just drop and went back up. I try to adjust the IACV and no luck. I talk to my tuner about the problem. He said that sometimes the o2 wen bad. My tuner switch my ecu to run on open-loop instead of close-loop. Have your tuner to set it run on open-loop. Try and see what happen.
Old Jul 5, 2006 | 12:41 PM
  #31
shortyz21's Avatar
Default Re: surging idle.....need help QUICK!!! (porsche997dc2)
open loop is when your not throwing any codes i believe...
yeah i replaced my IACV to.. nothing.
Old Jul 5, 2006 | 02:26 PM
  #32
raresi99's Avatar
Default Re: surging idle.....need help QUICK!!! (shortyz21)
talked to local tuner and said that tuning and switching the map sensor to a 3 bar one should take care of it... Or maybe switching to a 2 bar set up. O well it's going to the shop for tuning and dyno on monday
Old Jul 5, 2006 | 06:29 PM
  #33
bump for some more ideas....
Old Jul 6, 2006 | 11:57 AM
  #34
ok, i did a compression check now too, it's 185 on EVERY one of them...and it holds the pressure with no drop until you release it on the tester......also, i ran it on a cooler night last night, and it ran PERFECT the whole time? if this is how it's working wouldn't it be a tuning issue?
Old Jul 6, 2006 | 01:22 PM
  #35
iBrandon's Avatar
If you have a hondata gasket....be sure your intake mani bolts are tight, used with lock washers....sometimes the bolts back off...leaving a vaccum leak thru the gasket....also be sure your injects are fully seated...coulda came loose...
Old Jul 7, 2006 | 04:23 PM
  #36
shortyz21's Avatar
Default Re: (iBrandon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">If you have a hondata gasket....be sure your intake mani bolts are tight, used with lock washers....sometimes the bolts back off...leaving a vaccum leak thru the gasket....also be sure your injects are fully seated...coulda came loose...</TD></TR></TABLE>
yeah ive considered pulling my intake manifold off and putting a new hondata gasket in there.. but putting those JG manifolds on is a ****
Old Jul 7, 2006 | 08:41 PM
  #37
w0ng_sta's Avatar
would a leak of that nature throw a code?
Old Jul 8, 2006 | 02:27 PM
  #38
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themorphious &raquo;</TD></TR><TR><TD CLASS="quote">ok, i did a compression check now too, it's 185 on EVERY one of them...and it holds the pressure with no drop until you release it on the tester......also, i ran it on a cooler night last night, and it ran PERFECT the whole time? if this is how it's working wouldn't it be a tuning issue?</TD></TR></TABLE>
so no one has any ideas of what the problem could be?.....could it be the settings for fuel enrichment in crome? for IAT sensor readings?
Old Jul 10, 2006 | 02:53 PM
  #39
w0ng_sta's Avatar
Quote, originally posted by iBrandon »
Old Jul 10, 2006 | 03:04 PM
  #40
nickromeo's Avatar
the way i check for vaccum leaks is i pull of the intake tube and then block off the throttle body with my palm.
then engine will suck ur hand in,
then the car will stall cause ur stopping all the air from going in.
if the engine keeps running, u have a vacuum leak.
Old Jul 10, 2006 | 06:41 PM
  #41
b18prl's Avatar
what throttle body do you have obd 1 or obd2?
4tika4
Apr 19, 2009 09:43 AM
ReactioN
Mar 24, 2008 05:22 AM
EK Josh
29
Apr 11, 2005 11:05 AM
uszcrx
19
Jun 19, 2003 04:27 AM
