Surging idle, code 14 iacv
Old Jul 8, 2006 | 09:19 PM
EK k kay's Avatar
Default Surging idle, code 14 iacv
I've got this problem and I can't find a fix for it at all. After start up the idle surges from 1200-1600 then the surges get smaller and smaller until it idles fine and steady at 750 after about a minute. Code 14 IACV is coming up. I have done the 2-wire iacv conversion and it has been working just fine until I put my turbo on.
I have no vacuum leaks,
no boost leaks,
tried a new chip,
tried a new ecu,
tried a new(used) iacv,
tried re-wiring the iacv wires
tried a different obd2b to obd1 conversion harness
The thing is I get absolutely no codes when I plug the stock p2p ecu back in. It only does this when I run the conversion harness and chipped ecu with uberdata basemap. The code 14 is always on and I can't get rid of it even by resetting the ecu.
My setup is a stock y7 block with y8 head, t3 60/48, log mani, dsm 450's, chipped p75.
BIGef
Engine Management and Tuning
Oct 15, 2014 08:48 PM
sevenfc
45
Oct 15, 2009 03:52 AM
dad0c402
May 5, 2007 08:06 PM
slowpokecivic
10
Dec 22, 2006 06:40 AM
spatula
Jul 19, 2005 01:25 PM
