Supertech valvesprings?
Old Mar 31, 2009 | 08:27 PM
EFsSuck's Avatar
Default Supertech valvesprings?
im seeing two different part numbers for Supertech valvesprings for a BVTEC.
H1002D - 70lbs
H1000DR - 85lbs
setup is going to be a B18C in the sub 400whp range, running P72/GSR or CTR cams. and probably wont be reved higher than 8500rpms.
i would assume since im not running high lift cams or high RPMs i would want a lower seat pressure to lessen the wear/stress on the rest of the valvetrain. but im seeing the 85lbs springs listed as "turbo" springs?
Old Mar 31, 2009 | 09:22 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Supertech valvesprings?
i would get the 85lbs and run it to 9k why not? I have stock GSR's and i run them to 84
Old Apr 2, 2009 | 07:22 AM
EFsSuck's Avatar
no need to rev that high. wont make power there. also i might be running an 89mm crank.
Old Apr 2, 2009 | 07:29 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i bet you will with those ctr cams and an efficient set up especially with an 89mm
Old Apr 2, 2009 | 11:28 AM
SD_Lurker's Avatar
HT White Ops
I run 85lbs and so do most others but thats on a boosted motor.
Old Apr 2, 2009 | 12:23 PM
TcUiRvBiOc's Avatar
is it a must to run the 85lb springs on boost? i was inaware of the 2 different spring rates when i oredered mine, how much boost can i run on the 70lb springs? i wont b going over 8500 rpm
Old Apr 2, 2009 | 12:42 PM
SD_Lurker's Avatar
HT White Ops
You'll be fine man, don't worry!
Old Apr 2, 2009 | 02:06 PM
TcUiRvBiOc's Avatar
sweet man! i been stressin bout it ever since i looked at this thread haha! the supertech sales guy never even asked me what ones i wanted so i never knew till now dammit.. im spendin too damn much to have a 150 dollar set of springs screw me over
Old Apr 5, 2009 | 12:49 PM
EFsSuck's Avatar
whats the spring pressure on ITR/CTR springs?
TB123
Jun 16, 2010 04:25 PM
Civic89stdB16
Dec 1, 2008 12:05 AM
ella94
Apr 20, 2006 07:57 PM
sa21199
Feb 25, 2002 05:46 AM
