Supertech Valve Springs?
Old Sep 22, 2008 | 05:54 PM
boostedteg4dr's Avatar
Default Supertech Valve Springs?
I have a 450whp gsr turbo engine.
Stock head
I rev to 8200rpm as it sits
With 85lb supertch springs what will I be able to rev to safe?
Are these springs just as good for a daily driver as stock?
Do I need retainers, keepers, and valves? or just springs?
Thanks.
Old Sep 22, 2008 | 06:20 PM
rdeezy78's Avatar
Default Re: Supertech Valve Springs? (boostedteg4dr)
depending on miles on the valve train, it's always best to replace evrything if you can afford it. otherwise replace the most worn parts as you fit.
Old Sep 22, 2008 | 06:22 PM
platinum00's Avatar
I agree with rdeezy.... the springs will make it to 8200 if the rest of the valve train will.
Old Sep 23, 2008 | 05:54 PM
Default Re: Supertech Valve Springs? (platinum00)
can I install stock retainers with the supertech springs or is the spring rate to high to use stock retainers?
Old Sep 25, 2008 | 04:13 PM
platinum00's Avatar
The springs normally come with the retainers I thought. If not there cheap enough were you should get them too. They are designed to work together.
-platinum
Old Sep 25, 2008 | 10:22 PM
Jintegragsr97's Avatar
The springs that he has doesnt come with retainers, I have those too and i bought titanium retainers seperate.
Old Sep 26, 2008 | 01:08 PM
Default Re: (Jintegragsr97)
retainers are $170 more then I can get springs for.
RICE POLICE SIP
Aug 25, 2008 05:54 AM
chrisgottigsr
Feb 20, 2006 07:03 PM
Rod.
Mar 28, 2004 08:02 AM
