When starting car with JRSC installed car revs up like crazy!!!????? help
Old 12-10-2002, 01:49 PM
DeDonDeRosa's Avatar
Default When starting car with JRSC installed car revs up like crazy!!!????? help
just finsihed the install on a 97 GSR with the JRSC and when i go to start the car it just starts revving up so i had to shut it down and my friend who was looking at the motor when i did that said that the bypass valve was moving.
Old 12-10-2002, 05:35 PM
civ96's Avatar
Default Re: When starting car with JRSC installed car revs up like crazy!!!????? help (DeDonDeRosa)
good luck getting it runnin derosa
Old 12-10-2002, 05:41 PM
MiraiZ's Avatar
any loose vacuum lines? throttle stuck?
[Modified by MiraiZ, 11:42 AM 12/11/2002]
Old 12-10-2002, 05:53 PM
TREVER's Avatar
Default Re: When starting car with JRSC installed car revs up like crazy!!!????? help (MiraiZ)
major vacuum leak
Old 12-10-2002, 05:57 PM
metal-x's Avatar
Default Re: When starting car with JRSC installed car revs up like crazy!!!????? help (TREVER)
could be the the throtle is stuck opened like someone already said...
Old 12-10-2002, 06:32 PM
Rory Breaker's Avatar
When you shut the car off, the bypass valve should move, also depending upon throttle position.
How high does it rev? Throttle cable on correctly? Charger bolted on tight to manifold?
Old 12-11-2002, 05:06 AM
Default Re: When starting car with JRSC installed car revs up like crazy!!!????? help (newgsrdriver)
it revved to like 4 grand and then i shut it off
anyone know of anyone whoo this has happened to or anyone who would be able to fix this prob???
Old 12-11-2002, 06:12 AM
Have you checked the above recommendations?
Old 12-11-2002, 12:18 PM
Holden's Avatar
A 1/2" vacuum leak will make the engine idle above 3000rpm during cold start conditions.
Check the blower/manifold seal. That can cause a huge vacuum leak. Check throttle body gasket. It can be installed upside down. Check the oil/vapor recover system, another prime suspect for huge vacuum leaks.
The bypass valve will move by itself if the vacuum leak is big enough to really rev the motor.
Old 12-22-2002, 06:14 AM
2camsaam's Avatar
2 reasons.
Either severe vacuum leak, check between the intake many and the head or throttle body to the charger.
OR, throttle body is stuck open.
leighregan
03-24-2011 09:09 AM
MOVE OVER
07-31-2009 03:34 PM
TylerB
18
03-24-2006 08:58 AM
aka Paco
07-21-2004 10:34 PM
DeDonDeRosa
12-22-2002 06:13 AM
Quick Reply: When starting car with JRSC installed car revs up like crazy!!!????? help
