Supercharger maintenance
Old Mar 12, 2004 | 12:28 PM
EX R8ED's Avatar
Default Supercharger maintenance
How often should you replace the belts and pulleys on a JRSC if its at 6psi? What other type of maintenance is required for just the supercharger? Thanks.
Old Mar 12, 2004 | 01:54 PM
HNDAPWR's Avatar
Default Re: Supercharger maintenance (EX R8ED)
Belts last me about 10,000-15,000 miles at 11psi. Never heard of replacing pulleys though.No other maintainance required unless you over boost and score the charger blades. Some people replace the bearings after awhile if needed.
Old Mar 12, 2004 | 02:14 PM
Spunkster's Avatar
I only killed a pulley when my AC tensioner broke off and took the crank pulley and belts with it while on the freeway going about 85mph.
Lesson: Don't let monkeys overtighten your ac tensioner
Old Mar 12, 2004 | 04:45 PM
SwampThing's Avatar
whered you find monkeys?
ok on topic i think just the belts like he said and bearing if you really really feel the need. what motor do you have it on and how do you like it?
Old Mar 12, 2004 | 05:01 PM
greekspeed's Avatar
Default Re: (SwampThing)
the kit i used to have on my car was used for over 2 years, i had to preplace the blower belt once cause it broke off in the middle of a run at the track (THAT was embarasing...), and the tensioner pully for the alternator had a bad bearing which took a dump on it self as well....heh at least i had enough battery power to get home, and replace the bearing.
and my suspision for the ac tensioner was that i overtightend also.
but besides those 2 things i NEVER touched it as far as maintenance, and i beet the **** out of it daily.
Old Mar 12, 2004 | 08:18 PM
EX R8ED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote">whered you find monkeys?
ok on topic i think just the belts like he said and bearing if you really really feel the need. what motor do you have it on and how do you like it?</TD></TR></TABLE>
Thanks for the info fellas. Its on a B18B, and I love it
zcmotor
Oct 1, 2013 08:15 PM
PFCAcosta
Jan 28, 2011 05:08 AM
end005
Aug 31, 2010 06:42 PM
V8wannabe
May 6, 2010 12:56 PM
redacura
May 26, 2008 03:57 PM
