Super-T dyno run
Old Sep 12, 2003 | 06:01 PM
TheShocker's Avatar
Default Super-T dyno run
Sitting at the dyno typing this right now (getting ready for Joliet this weekend)...just hit 697 WHP, 674 TRQ @ 29 psi tonight. (2JZ stock head, cams, block). This was a spike on the graph, but power levelled out at 650 WHP (28 psi).
As some of you know, earlier in the year we ran a 10.5@132 MPH and that was on 19 psi which made 480 WHP. We're hoping for some 9s this weekend with the extra ~200 HP! We'll see those of you there who are going at the track. Don't be shy to come and introduce yourself!
-Seth
Old Sep 12, 2003 | 06:03 PM
ricodemus's Avatar
Default Re: Super-T dyno run (TheShocker)
holy torque boostman!
with traction, you shouldn't have much problem it seems to hit 9s.
Good luck!
Old Sep 12, 2003 | 06:21 PM
Giblet Plus!'s Avatar
Where in MN is this?
Old Sep 12, 2003 | 06:33 PM
DigitalFusion's Avatar
joilet is the suburbs of chicago
Old Sep 12, 2003 | 07:30 PM
Turbocivic94's Avatar
gotta love 2JZ
Old Sep 12, 2003 | 07:35 PM
greekspeed's Avatar
bad ***
Old Sep 12, 2003 | 07:38 PM
shermanyang's Avatar
Default Re: Super-T dyno run (25 PSI CRX)
Holy Cow!! I'd give almost anything to make that much power!! *drool*
Good luck Seth...I've heard a lot of people here in MN talking about going to Joliet rather than RockFalls this coming up weekend. Also heard you get better time slips down there due to elevation...this true?? I haven't been there so I wouldn't know...
Old Sep 12, 2003 | 07:43 PM
Evil EG's Avatar
Default Re: Super-T dyno run (greekspeed)
nice hope to see you guys run good. Are you guys gunna be in the same class as the Sound Performance Supra? Id like to see that race.
Old Sep 12, 2003 | 08:12 PM
lazerus's Avatar
Default Re: Super-T dyno run (BVM)
what turbocharger are you using on your setup?
Old Sep 12, 2003 | 08:27 PM
Ri5e's Avatar
Default Re: Super-T dyno run (lazerus)
2JZ Blocks are strong
Old Sep 12, 2003 | 08:32 PM
DIRep972's Avatar
Smarter than you
not too bad. im really a supra owner deep down inside. what kinda turbo?
Old Sep 12, 2003 | 09:07 PM
paulzy's Avatar
This is impressive Dave, Alyssa, Seth....I think last time they used a t72(which I'n sure they're still using).
THe reason why everybody gets such good 1320 times is because Route 66 is sticky as gum
Old Sep 12, 2003 | 09:11 PM
Racergurlie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Twin Cities
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">what turbocharger are you using on your setup?</TD></TR></TABLE>
Turbonetics T72 P-trim .81 A/R...crappy-*** on-center exhaust housing
-Seth (oops, forgot to log Alyssa off)
Old Sep 12, 2003 | 09:20 PM
TheShocker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM &raquo;</TD></TR><TR><TD CLASS="quote">nice hope to see you guys run good. Are you guys gunna be in the same class as the Sound Performance Supra? Id like to see that race.</TD></TR></TABLE>
Yeah we should be in the same class.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Good luck Seth...I've heard a lot of people here in MN talking about going to Joliet rather than RockFalls this coming up weekend. Also heard you get better time slips down there due to elevation...this true?? I haven't been there so I wouldn't know...
Thanks man! I don't know about elevation, I think it's about the same as in MN, but I guess I don't know for sure. The track is just awesome; many racers would agree it's one of the best in the country.
-Seth
Old Sep 12, 2003 | 09:26 PM
TotalJDM.com's Avatar
NICE NUMBERS!
Andre
Old Sep 12, 2003 | 11:02 PM
Evil EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Good luck Seth...I've heard a lot of people here in MN talking about going to Joliet rather than RockFalls this coming up weekend. Also heard you get better time slips down there due to elevation...this true?? I haven't been there so I wouldn't know</TD></TR></TABLE>
If I remember right its about 300ft above sea level.
Old Sep 12, 2003 | 11:23 PM
Boostfed's Avatar
New User
Good luck! I hope 9's are in it for you guys! Nice dyno #s! And a for Alyssa
Old Sep 13, 2003 | 06:55 AM
paulzy's Avatar
If I remember right its about 300ft above sea level.</TD></TR></TABLE>
thanks....I if remember, ROck falls is about 80 ft above sea level
Old Sep 13, 2003 | 10:09 AM
Drag_On's Avatar
Rock Falls has good elevation and bad track prep..
Joliet is a good track yes-- but probably not worth th 7 or 8 hour drive from the cities considering you can drive to Rock Falls in an hour or here in 2.5
Old Sep 13, 2003 | 03:32 PM
Smashback's Avatar
This is the kind of truck I need for a "beater" pickup! Sweet job!!
Old Sep 14, 2003 | 12:54 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Super-T dyno run (PseudoSilvia)
Gummy Route 66 starting line + extra new found power = driveline failure.
Nice 1/4 twist added to the middle of the driveshaft.
Old Sep 14, 2003 | 01:47 PM
paulzy's Avatar
Default Re: Super-T dyno run (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Gummy Route 66 starting line + extra new found power = driveline failure.
Nice 1/4 twist added to the middle of the driveshaft.</TD></TR></TABLE>
yeah, heard about that....Dave said it was the whole rear end that twisted
Old Sep 14, 2003 | 03:24 PM
GOLDBERG's Avatar
Default Re: Super-T dyno run (Paul_Vang)
nice #'s....any honda #'s?(big ones)
Old Sep 15, 2003 | 11:42 AM
Default Re: Super-T dyno run (GOLDBERG)
Launched off the two step at 5500 rpm, twisted the driveshaft, tore the mounts off the rear end housing, the housing then rotated upwards, yanking the driveshaft out and slightly bending the output shaft on the transmission as it now howls and doesn't shift for ****...
Found a local junkyard, they had a housing, got it, had the old rear end swapped out by 930pm. Other racers at the track were EXTREMELY helpful...
Next day, First pass, slipped the clutch off the line, but wouldn't go into 3rd or 4th...aborted pass...
Next pass, slipped it off the line, went to go for third, with a little persuasion it went in(well, a couple of seconds of persuasion) Boost came back on, hit fourth, Ran a 11.3 @ 137mph...
Oh well...need a new tranny...
9's will have to wait...
Oh yeah, case you didnt know, we swapped in a five speed before the race...no more powerglide...
Alyssa Kay
Old Sep 15, 2003 | 11:52 AM
paulzy's Avatar
Default Re: Super-T dyno run (Racergurlie)
damn, shoulda kept the powerglide...
