is this a substitute for sleeving?
Old Mar 6, 2006 | 06:55 AM
Sleepy_Red_hatch's Avatar
Default is this a substitute for sleeving?
is this a substitute to sleeving? how does it work? is it installable at home? anyone have any info about this?
Old Mar 6, 2006 | 06:58 AM
Soccerking3000's Avatar
Default Re: is this a substitute for sleeving? (Sleepy_Red_hatch)
not a substitute... they havent been proven to do anything at all... likewise they havent been proven to do anything harmful either...
Old Mar 6, 2006 | 07:01 AM
Default Re: is this a substitute for sleeving? (Soccerking3000)
well it seems as thogh it would seal the deck i dont get how they are installed or anything thogh
Old Mar 6, 2006 | 07:19 AM
pdiggitydogg's Avatar
Installed roughly 1/4" down from the top of the deck, around the sleeves.
They are supposed to keep the sleeves from moving about or ovaling.
Definately not a resleeving substitute.
They need to be machined in, not beat with a hammer, and cylinder walls need a hone afterward.
Old Mar 8, 2006 | 02:52 PM
Default Re: (pdiggitydogg)
interesting...
Old Mar 8, 2006 | 03:00 PM
tallyturbo's Avatar
Default Re: (Sleepy_Red_hatch)
search blockguard and a million topics will appear.
Old Mar 8, 2006 | 03:21 PM
x2gold's Avatar
that is true..they are roughly 65- 85 for b series. and a little cheaper for d series, but similar in price. These are NOT a comparison for sleeving.
Old Mar 8, 2006 | 04:55 PM
urbansi's Avatar
Default Re: (x2gold)
Looks like this, installed on a accord V6
Old Mar 8, 2006 | 05:16 PM
HKSuperSi's Avatar
i heard it doesn't do anything and its useless.
Old Mar 8, 2006 | 05:32 PM
urbansi's Avatar
Default Re: (HKSuperSi)
Thats why you have nothing to say about this then in my opinion.
No expierence=no opinion=no reason to comment. JMO
Search+read-then comment.
Old Mar 8, 2006 | 10:13 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: (urbansi)
block gaurds help avoid cylinders "walking" where the sleeves move and oval out like pdiggitydogg mentioned at the beginning. dunt think for a minute that block gaurds can actually stop sleeves from cracking because they don't. detonation will crack stock sleeves, stock sleeves with block gaurds, and even aftermarket sleeves. ive heard of people using them and they seemed to be satisfied with them but i also hear some negative things about block gaurds. given the opportunity to use one, i chose not to. the <FONT COLOR="red">SEARCH</FONT> button helped me, a lot to read about
Old Mar 8, 2006 | 10:43 PM
LilCivic04's Avatar
Default Re: (JDM turbo DC)
well i have been using mine for 8thousand miles so far and no problem. i am using an rc engineering one. also i had changed cylinder heads few thousand miles and check it again just in case and it look just the same as i installed it
Old Mar 8, 2006 | 11:03 PM
ccfab's Avatar
Default Re: (LilCivic04)
you need to get yourself a lb of decon liquid aluminum f-2
Old Mar 8, 2006 | 11:35 PM
Default Re: (ccfab)
can't sleep either?
Old Mar 8, 2006 | 11:49 PM
tek_civic's Avatar
Default Re: (Soccerking3000)
haha i asked him the same question a couple days ago
seriously though, i would advise against a block gaurd, for what you have to go through to install it correctly(or risk being worse off than when you started) its just not worth it. especially when its just so small of a piece of metal, the best it will do is stop the cyl from walking a little.
if you want a real alternative for sleeving on the cheap(cheaper than a blockgaurd), that works MUCH MUCH better, check out this thread. like he said devcon is teh shet. https://honda-tech.com/zerothread?id=1444721
Old Mar 8, 2006 | 11:59 PM
Default Re: (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">haha i asked him the same question a couple days ago </TD></TR></TABLE>
weird
bzyq2001
Sep 18, 2009 01:45 PM
mrkal
Jan 25, 2006 07:02 PM
TurboSam
Sep 27, 2004 03:28 PM
nevin
Jun 9, 2004 08:51 AM
99B16Si
Feb 8, 2004 10:32 AM
