Stuttering engine.
Old Sep 16, 2006 | 10:43 PM
HamiltonRex's Avatar
Default Stuttering engine.
Today i was driving home and sometimes the car would stutter.. felt like it was missing.. It isnt load/gear/speed/rpm dependant, and will just do it sometimes for a sec. Oil pressure is good, it isnt going lean on the wideband.. and its still building boost normally. no cels. I feel its an ignition issue.. I washed under the hood today, maybe some water got where it shouldnt?
I did a 5th gear 'semi' pull on the way home.. just up to about 100-105mph, i was at only 60% throttle just cruising.. It was fine then too, ran normally.
Could water get into the spark plug boot/area and cause this? It was only a few hours after i washed it. I havent really done much looking around under the hood to see what could be the problem. Its a new cap/rotor from honda, as well as new plugs.. BRK7's, i have a spare set i may change if problem persists, as well as maybe pull the cap off and investigate under there.
Car has ran great all year. So could water be the culprit? I figured the heat from the engine would just dry it up shortly.. What should i look into first?
Setup is just a stock block B18C at 7psi, street tuned.
Modified by HamiltonRex at 11:55 PM 9/16/2006
Old Sep 17, 2006 | 05:52 AM
DaveF's Avatar
Default Re: Stuttering engine. (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">some water got where it shouldnt?
water get into the spark plug boot/area and cause this? </TD></TR></TABLE>
yes it happens.
Old Sep 17, 2006 | 08:18 PM
Default Re: Stuttering engine. (dturbocivic)
I pulled the cap off the dizzy, pulled the wires, cleaned everything, and put it all back together and problem still persists..
I got almost all the way though 3rd at WOT around 7k it just backfired, and i let off. Sometimes it happens at 3k sometimes 6-7k etc.. Throttle position dosent matter as well as load.
I will swap ignition setups with my friend dizzy/wires and put in my spare set of plugs.. See if the problem persists.
Does anyone have any pointers on how to diagnois between fuel and ignition ? Im pretty sure its an ignition though. since it only seems to be happening after ive been driving for 15-20minutes and the cars been at temp for awhile.
TYIA!
Old Sep 17, 2006 | 08:39 PM
Akalima's Avatar
Just went through the same thing last week. It turned out it was just my coil runs awesome now. Cheap and only took half hour
Old Sep 19, 2006 | 04:12 AM
Default Re: Stuttering engine. (Akalima)
didnt do it yesterday at all... car didnt get a chance to get hot for along time only drove 15-20 min each way. Gonna swap dizzy's maybe today.
JusAccord
Jan 15, 2012 11:03 AM
hafaadaiteg
Aug 28, 2007 07:21 PM
civiccoupe94
Feb 12, 2007 08:14 PM
Mr.Death
Jul 29, 2006 02:52 PM
