studs question for manifold..
Old Dec 18, 2002 | 08:45 AM
TurbothisLS's Avatar
Default studs question for manifold..
ok i using studs instead of bolts for my turbo mani and so i went and paid like $2.80/ea for them at acura.
anyway, before i put them in do i need to do anything (i.e. put threadlock) to the side that goes into the head, or do i just screw them in?
thanks
Old Dec 18, 2002 | 08:59 AM
rjardy's Avatar
Default Re: studs question for manifold.. (TurbothisLS)
just run them in and make sure they are tight, use the 2 bolt trick, im sure you allready know that.
Rob
Old Dec 18, 2002 | 04:56 PM
Default Re: studs question for manifold.. (rjardy)
2 bolt trick?
i know i may seem smart...
but please explain.
Old Dec 18, 2002 | 07:35 PM
JMinSi2000's Avatar
I think he means double nutting. Put two nuts on the end of the stud and tighten them together. Then use the outer nut to torque the stud in. Use the inner nut to pull them out.
Old Dec 19, 2002 | 03:20 PM
Default Re: studs question for manifold.. (JMinSi2000)
ohh
cool, i'll try it
does anyone know if the stud will stop at some point?
Old Dec 19, 2002 | 03:26 PM
JV's Avatar
JV
Who?
You wouldn't happen to still have a part # for those...? I would like to do the same with my LS...
Old Dec 19, 2002 | 03:31 PM
Default Re: studs question for manifold.. (JV)
yeah i still have the packaging.
i'll check and post when i get home.
Old Dec 19, 2002 | 03:40 PM
JV's Avatar
JV
Who?
Sweet. Thanks...
leroy12
Feb 12, 2010 12:41 PM
oodie
Aug 20, 2009 10:54 PM
Civicman86
Oct 27, 2005 10:24 AM
95GSRTT
Apr 30, 2005 05:57 PM
