studdering
Old Jan 28, 2005 | 12:28 PM
coupon's Avatar
Default studdering
i read a thread about a car studdering when its low on gas while turning...well my car is studdering when im going straight. im running a walbro (high pressure 255) with an oem filter instead of a walbro filter.
b18c1 and percision 880
Old Jan 28, 2005 | 12:52 PM
b18bturbo's Avatar
Default Re: studdering (nlc)
studdering like igntion miss or what exactly what are you using to control the fuel most likely gonna be related to your tune
Old Jan 28, 2005 | 04:59 PM
coupon's Avatar
Default Re: studdering (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">studdering like igntion miss or what exactly what are you using to control the fuel most likely gonna be related to your tune </TD></TR></TABLE>
i dont know how to explain it, when i give it gas it just studders, but the rpm's will rise? its just like how the other guy posted about him it happening when he was turning, mine only use to do it on turns but now it happens when im accelerating no matter what. and it has a real hard time idling
Old Jan 28, 2005 | 05:21 PM
b18bturbo's Avatar
whats your fuel pressure like. It might be the pump failing its good posibility.
its good for you to check it out and see your fuel pressure at the rail. If its constant and on boost is rising accordingly then it something else
Old Jan 29, 2005 | 07:16 AM
coupon's Avatar
weird my freind is having the same problem
im gunna fill up on gas tonight and see if it makes any diff
Old Jan 29, 2005 | 09:17 AM
coupon's Avatar
Old Jan 29, 2005 | 09:55 AM
coupon's Avatar
Old Jan 29, 2005 | 05:45 PM
coupon's Avatar
help
Old Jan 29, 2005 | 08:16 PM
warrick's Avatar
Default Re: (nlc)
check that all injectors are firing, check plugs, wires, cap, rotor. change the filter.
did you check the fuel pressure? check it.
Old Jan 30, 2005 | 07:39 AM
coupon's Avatar
Default Re: (warrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick &raquo;</TD></TR><TR><TD CLASS="quote">check that all injectors are firing, check plugs, wires, cap, rotor. change the filter.
did you check the fuel pressure? check it.</TD></TR></TABLE>
how do i check if the injectors are fiting? and the fuel pressure?
Old Jan 30, 2005 | 08:06 AM
johnnylawless's Avatar
Default Re: (nlc)
check your plug gap,you might be blowing the spark out.
I had problems like that and had to go tighter on my gap (.025)
semms to have taken care of the prob for me.
worth a try!
Old Jan 30, 2005 | 09:34 AM
coupon's Avatar
Default Re: (johnnylawless)
gunna look into that too
Old Jan 30, 2005 | 10:05 AM
warrick's Avatar
Default Re: (nlc)
to check if the injectors are firing, you have a couple of methods. take a screwdriver and touch it to the injector, and "listen" to the handle to see if it is ticking.
you can also get a logic probe or an actual tester for it.
Old Jan 30, 2005 | 07:58 PM
coupon's Avatar
Old Jan 30, 2005 | 09:58 PM
raene's Avatar
If your tune is off it will cause this type of stuttering. I know 'cause my car does it
Old Jan 31, 2005 | 12:40 AM
coupon's Avatar
Default Re: studdering (raene)
yeah i need a retune, i just got home. hopefully more gas will do the trick
The Dirty EJ1
Apr 10, 2008 03:58 PM
hondachris1994
Aug 19, 2006 08:31 AM
hondapwred95
May 4, 2006 06:09 AM
fattymatty
Apr 14, 2005 03:57 PM
LAKER HATER
Mar 30, 2004 06:45 PM
