studdering
i read a thread about a car studdering when its low on gas while turning...well my car is studdering when im going straight. im running a walbro (high pressure 255) with an oem filter instead of a walbro filter.
b18c1 and percision 880
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">studdering like igntion miss or what exactly what are you using to control the fuel most likely gonna be related to your tune </TD></TR></TABLE>
i dont know how to explain it, when i give it gas it just studders, but the rpm's will rise? its just like how the other guy posted about him it happening when he was turning, mine only use to do it on turns but now it happens when im accelerating no matter what. and it has a real hard time idling
whats your fuel pressure like. It might be the pump failing its good posibility.
its good for you to check it out and see your fuel pressure at the rail. If its constant and on boost is rising accordingly then it something else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick »</TD></TR><TR><TD CLASS="quote">check that all injectors are firing, check plugs, wires, cap, rotor. change the filter.
did you check the fuel pressure? check it.</TD></TR></TABLE>
how do i check if the injectors are fiting? and the fuel pressure?
to check if the injectors are firing, you have a couple of methods. take a screwdriver and touch it to the injector, and "listen" to the handle to see if it is ticking.
you can also get a logic probe or an actual tester for it.
The Dirty EJ1
Apr 10, 2008 03:58 PM
