Stubborn headstud removal
Old May 21, 2009 | 08:29 AM
aztecracer1's Avatar
Default Stubborn headstud removal
Was given a GSR bare block with headstuds that were installed on the block, question is that the headstuds will not come out. Does anyone have any suggestions, don't care about the studs but would like to keep the block from damage. Thinking about a propane torch to heat up the studs and then double nut.
1. tried double nuts on the studs.
2. Vise grips.
3. over night with PB Blaster.
Old May 21, 2009 | 08:58 AM
kyden's Avatar
Default Re: Stubborn headstud removal
what headstuds? arp's have an allen key on top.
Old May 21, 2009 | 09:51 AM
HiProfile's Avatar
The problem with heat is you'll likely ruin the studs. If the previous owner used strong locktite, you'll have to heat it to the point where the stud's metal structure changes (for the worse).
I'd try an impact wrench on it, although on the LOW settings. You just need to break the locktite's bond.
Old May 21, 2009 | 10:18 AM
turbo-crx's Avatar
the double nut thing should work. i used it on my last block
Old May 21, 2009 | 08:48 PM
boport's Avatar
They are more than likely loctite'd in and a little heat from just a propane torch should break the loctite down and do the trick. Heat the surrounding area of the stud, not the stud itself as suggested.
Old May 22, 2009 | 05:34 AM
Turbocivic94's Avatar
Heat the stud not the block.
Old May 22, 2009 | 06:38 AM
redlinetuning's Avatar
You're not even supposed to use loctite on ARP head studs. At any rate, if you can't remove them using the allen wrench, then get a stud puller. A cam/wedge puller usually does the job.
http://buy1.snapon.com/catalog/tools...e=snapon-store
Old May 22, 2009 | 06:45 AM
hootiehoo's Avatar
http://performanceparts.com/part.php?partID=88394
ive used this thing before on the shank of the stud.
it works. put it in an impact.
as to breaking loose red loctite, you dont have to heat to change the properties of the stud, thats bs. a propane torch will get it hot enough to break loctite loose, and you not going to heat treat tthe stud with propane for a min or so.
Old May 22, 2009 | 09:53 AM
twkdCD595's Avatar
Using some heat like said above should help get them loose if double nutting them wont work or have an allen key that will hold up to trying to loosen them with some force.
ARP actually says you CAN use loctite on the stud end going into the block. I called them to check as I had an issue with studs backing out of block. Its on their install sheets as a note line that it may be used in more permanent install applications if desired, BUT the studs must be torqued to spec prior to the loctite setting up. It can also be used in applications where the studs thread into a water jacket and need to be sealed.
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
skiracer8148
17
Apr 1, 2007 09:17 PM
LSEGHATCH
Aug 19, 2005 10:53 AM
crexSIvtec
Mar 22, 2005 11:48 PM
clsmooth
Aug 24, 2003 06:47 PM
