stroke it or dont stroke it
Old Jan 31, 2006 | 11:15 PM
  #26
beerbongskickass's Avatar
Default Re: stroke it or dont stroke it (EnzoSpeed)
Why do I always have something to say? Because I see sooooo many people are doing things the WRONG way. People make things way more complicated than they really are. Having tons of instant torque on a FWD car with dinky tires is retarded... it's useless on the street. 1st and 2nd gear in my car are useless unless I have my drag radials on, and I don't make near the power/torque your talking about making. You will have to get a staged boost controller, LSD, drag radials, good suspension, traction bars, etc... and your still going to have a hard time putting it to the ground! But hey if that sounds fun to you, go for it.
Oh and sc4dr don't you have a supercharer on a honda? That's about as smart as boosting a b20 lol...
Old Feb 1, 2006 | 08:45 AM
  #27
saver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">
I'm guessing it's because this thread is packed with retards.</TD></TR></TABLE>
well if you think you have more knowdlge then these guys on this thread then tell me wat do you think.
o and beerbong you are completely right about the rwd being good for TQ. thats why i have been searching and thinking about getting a diffrent car that has a RWD. and nvm mind about the evo 9.
Old Feb 1, 2006 | 10:29 AM
  #28
Boostage's Avatar
Why jump all over BBKA? he is speaking the thruth, even if its not what you want to hear. stroking makes alot more sense for all motor guys.
Old Feb 1, 2006 | 01:27 PM
  #29
TrueNorthStar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Just remember that stroking a motor shortens it's life. Longer stroke = more stress on the rods. I personally hate stroked motors. I overbore everything.</TD></TR></TABLE>
Most of the additional stress is from the poor r/s ratio of the stroked motor. Stroke increase needs a decrease in rod length.
Now if you deck plate the motor so you can run a longer rod and keep the r/s in check, it will prolong the life of the stroker motor by reducing the amount of side loading the pistons see.
The one thing you can't get away from in a stroker motor is piston speed.
@9000 rpm a stock stroke gsr piston is moving at 5149fpm.
@9000 rpm a 92mm stroker piston is moving at 5433fpm.
On my motor I'm running a Dart tall deck w/92mm crower stroker kit. With the tall deck my r/s is 1.69/1 (gsr/itr is somewhere around 1.59/1)
I really enjoy the torque that the stroker makes, but for cost reasons, it is not for everyone.
Old Feb 1, 2006 | 09:29 PM
  #30
saver's Avatar
Default Re: stroke it or dont stroke it (TrueNorthStar)
ya know he is saying it for the good i guess thats why im not tripping over anymore. thanks. anyways i dont think i would want to have it stroked since i want it to last a long time and for a daily driver. wat psi are you running your turbo with the stroker.
Old Feb 1, 2006 | 09:32 PM
  #31
saver's Avatar
Default Re: stroke it or dont stroke it (saver)
hey beerbong is your Dmotor good for the streets to. ive always wanted to try a turbo Dmotor. just cause of the TQ it gives out. and the low cost of the motor if it blows. where are you redlining and your shifting.
k about traction cause i just found out that im keeping the DA so.... to get that traction of a FWD wat would be the best way. would a dampner work with a traction bar and rods, LSD, and wat else. well to keep it as a nice budget.
Modified by saver at 10:56 PM 2/1/2006
Old Feb 1, 2006 | 10:12 PM
  #32
HiProfile's Avatar
All it takes is a bit of searching (that means getting your head out of your asses) to see what the lowly d-series puts out. Even stock blocks limited by tiny rods (or should I say lightweight rods ) is making more TORQUE than some built b18 motors. 200-250wtq is nothing to laugh at. Even 3rd gear doing 50mph results in 4k rpm, giving you 152whp (if you're making the typical 200wtq of a low boost D16). And based on the extra you pay for a b-series tranny vs. a d-series, it is certainly not unreasonable to buy a 4.9 final drive kit (or 4.7, whatever it is) offered by some mfg, and never have to downshift.
Anyways, this brings up the main point. Increasing stroke improves torque (low mid power), increasing bore improves dyno numbers (mid-top power). And with most cars being daily drivers with street tires, why would you need more torque than most V8's? The other deal is that wider bores require more timing advance, and that results in greater risk of preignition.
Old Feb 2, 2006 | 03:57 PM
  #33
saver's Avatar
Default Re: stroke it or dont stroke it (HiProfile)
good deal man. thats the best ive heard so far. thanks. ya i realized that storking it is not worth it at all. i guess that would be my next project later on my future with a nissan 240sx. thats the car i wanted but i got stuck with this car just cause i did a ******* contract. im sticking with the Bmotors for a DD and maybe a Dmotor for drag.
chewymonster
10
Feb 14, 2007 08:10 AM
4CDFED
Aug 17, 2006 08:29 AM
greddy13
Jan 27, 2006 02:54 PM
xfrankx
Aug 18, 2005 06:21 PM
Glocker
Aug 16, 2005 08:29 PM
