Strange Idle..
Old Jun 5, 2004 | 01:47 PM
J337_UNIT's Avatar
Default Strange Idle..
I have a hondata and DSM injectors ....one thing i noticed is sometimes i get a strange idle. Usually it is like ROCK steady, but there are times when ill start it up and usually its when its extremely hot out and after the car is fully warmed up the idle might bounce aroudn a little bit.. its not drastic but its not rock steady like it usually is, and another thing is sometimes ill get like some popping at idle..its very quiet popping. My question is, is this related to outside air temperatures... The tune was done in like 55 degree weather.. and at nights when its around that temp is when the car idles and drives the best, but during the day when its like 70-80 degrees out the car feels sluggish and cant hold a rock idle as great. any help is welcomed TIA
Old Jun 5, 2004 | 10:21 PM
J337_UNIT's Avatar
Default Re: Strange Idle.. (J337_UNIT)
bump
Old Jun 6, 2004 | 01:16 PM
numba1's Avatar
check your idle air controll valve (iac) in back of the manifold, I had the same problem as you, tried everything changed gaskets,map sensor,adjusted tps sensor, v-afc adjustments nothing still the same then I checked my helms manuel,It said that rough idle #1 to check iac valve, and DAMN sure enough swapped it out with my partners and bam back to a rock steady 760-790ish rpm. try that hope it works for you.
Old Jun 6, 2004 | 01:19 PM
numba1's Avatar
Default Re: Strange Idle.. (numba1)
Oh yeah forgot to tell you even though it was faulty(iac) the cel light never came on thats why i never thought it was bad,who knows? But just give it a try.
Old Jun 6, 2004 | 02:09 PM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
Yeah, I'm gonna have to try that. I have a bouncy idle sometimes. I'm gonna try doing that and adjusting my timing, cuz I think mines is off a lil bit.
Old Jun 6, 2004 | 02:31 PM
J337_UNIT's Avatar
Default Re: Strange Idle.. (acuracrombie82)
numba1 i appreciate the response.. i guess ill try to clean mine or swap it and see how that does.
mikeunreal2
11
Mar 23, 2006 12:00 PM
Civicse
Feb 7, 2005 11:52 AM
sydag5
Mar 26, 2003 08:42 AM
s2k
Feb 25, 2003 06:50 PM
91SE
Feb 18, 2003 04:35 PM
