Idle problems with turbo
Old Mar 25, 2003 | 07:16 PM
sydag5's Avatar
Default Idle problems with turbo
Ok i fixed my idle kind of. Yesterday the car wouldn't idle at all. Today I took out the IAC valve and cleaned it started the car and it idled normal all the way until it was fully warmed up. So I took it for a drive came back home and during cool down the idle just shoots back up to 1500rpms and idles there. Now when I start it up it idles high when its cold like any normal car does when its cold. Then when it gets up to temp it idles normal 900-1000rpms then after about 5 minutes after being at temp the idle jumps back up to 1500rpms i have no idea what is wrong. Also, when it idles normal for that 5 minutes the idle fluctuates between 900-1000rpms and the vacumm gauge fluctuates between 15 and 20. Does anyone have any ideas
[Modified by sydag5, 4:18 AM 3/26/2003]
Old Mar 25, 2003 | 07:38 PM
sydag5's Avatar
Default Re: Idle problems with turbo (sydag5)
anyone
Old Mar 25, 2003 | 07:47 PM
T-sohctec's Avatar
so you know if your IAC valve is actually working? if you know for sure it works start checking for vac leaks.
what did you do for your fuel mangmt.
Old Mar 26, 2003 | 08:42 AM
sydag5's Avatar
Default Re: Idle problems with turbo (T-sohctec)
Hondata s100 with boost
walbro intank 255lph
accord 380cc injectors
stock fuel pressure
TearSDMF89dx
Jan 3, 2012 04:31 AM
jdmgeezer
Dec 9, 2007 11:23 PM
spock_rocker
Oct 17, 2007 08:11 AM
riceburnah
Sep 26, 2004 12:38 PM
