stock oil cooler with GE oil sandwich (searched)
hey guys,
i just ordered the GE oil sandwish adapter to feed my turbo filtered oil, but just yesterday i just realised am already running a stock oil cooler and honestly i dont want to throw it....its really hot where i live and i dont know if i run both stock oil cooler and oil sandwich adapter?
let me know if its possible and if i can still use the stock center bolt/stud?
lets say its possible which should fit first on the block the sandwich adapter or stock cooler?
Re: stock oil cooler with GE oil sandwich (IntegraTypeR)
by the way the reason am asking cause most of the pics i have seen on here regarding the oil sandwich adapter i never saw a stock oil cooler
Re: stock oil cooler with GE oil sandwich (red_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_crx »</TD></TR><TR><TD CLASS="quote">you don't remove your stock oil cooler.....it goes over it.</TD></TR></TABLE>
well i got my GE adapter just today and it came with the center bolt/stud....should i use the stock one am still using or use the one from GE? i guess GE cause it should be extended right?
You put the adapter plate around the stock stud, then screw the GE stud onto the stock one to hold the adapter in place. Once you get under there, you'll figure it out.
R-Toyz.com
04-04-2007 05:34 PM
