stock fuel pump problem
Old Jan 11, 2004 | 08:14 PM
Realvibez's Avatar
Default stock fuel pump problem
what is the most boost that you can run safely on a stock honda fuel pump. my setup is b16, t3/t4, rc 440, greddy e-manage. is 10 psi ok or do i need to upgrade my pump.
thanks
Old Jan 11, 2004 | 08:30 PM
xxxmikenicexxx's Avatar
Default Re: stock fuel pump problem (Realvibes.net)
You should at least put in an inline to raise the pressure to be safe...
Old Jan 12, 2004 | 06:50 PM
scttydb411's Avatar
always wideband tune to be sure of whatever you have/do. i still run my stocker and that's at 10-11psi on a td04L on my d16y7...afr 11-12. i have a 255 to drop in, but i'm too lazy.
Old Jan 12, 2004 | 06:53 PM
turbotypeR@SPEC's Avatar
25 Year Member
zero
Old Jan 12, 2004 | 06:58 PM
nsxmatt's Avatar
Did your car come with a B16 or was it a single cam? Single cam pump, no way. Si/GSR pump maybe get my but why risk it. If your running larger injectors and no fmu throw a intank in there.
Old Jan 13, 2004 | 10:11 AM
Realvibez's Avatar
alright thanks, it was a b16 swap. i will just get an intank to be safe.
Old Jan 13, 2004 | 12:33 PM
RedTegLS's Avatar
Default Re: (Realvibes.net)
There is a special in the sponsor market place right now for Walbro intanks for $80 w/ install kit. That is NICE!
deacs
Sep 20, 2002 12:27 PM
DJ0820
Aug 1, 2002 11:56 AM
dwilson
Apr 10, 2002 08:41 PM
