are stock cams....
Old Jul 10, 2001 | 10:26 PM
hydroflip's Avatar
Default are stock cams....
are stock cams good for a turbo car???
Old Jul 10, 2001 | 11:00 PM
Ricehornet's Avatar
Default Re: are stock cams.... (hydroflip)
maybe if you told us what car you have it would help
but to jump the gun and take assumptions, stock cams are good for turbo because the more overlap you get, the worse, cause the air just blows right through while it can be pressing in....lift is good if i remember, cause if it lifts higher, more air goes in but duration, if both exhaust and intake are long, overlap will occur, and i already told you why that is bad.....so like...CTR cams vs GSR cams, i would stick with GSR cams....cam gears are very useful at this point to tune the cams to optimize them for a force fed car. HTH
Old Jul 10, 2001 | 11:51 PM
hydroflip's Avatar
Default Re: are stock cams.... (Ricehornet)
thanks!!im learning...hehe...by the way...its a LS engine in a civic 94...
Old Jul 11, 2001 | 01:16 PM
VRxDReGoNxGSR's Avatar
New User
So your saying that i should just keep my gsr cams because i am getting a turbo soon and i was about to buy some ctr cams but why are my gsr better for turbo anyways???
Old Jul 11, 2001 | 01:25 PM
b18bturbo's Avatar
Default Re: are stock cams.... (VRxDReGoNxGSR)
yes stock cams are the way to go. You can go with a mild cam if you know what you are doing. I especially like the new crane cams.
Old Jul 11, 2001 | 09:46 PM
dbman96's Avatar
New User
I think any Type R series cam will do you less good; they're designed to wring that last few hp out of a naturally aspirated car; the overlap will almost certainly be fighting you so you'll end up dialing the overlap out with adjustable gears and negating whatever benefits the cams might have offered. Just stick with the stock cams and tune, tune, tune!
Save the cam money you would have spent and put it into a "standalone ECU" savings account.
Old Jul 11, 2001 | 10:17 PM
TurboInteg95's Avatar
keep the stock cams, they work fine.
EJ8 GSR-T
Jul 21, 2006 11:02 PM
B18 CYA
May 30, 2004 04:45 PM
MysteriousGSR
Apr 15, 2002 06:47 PM
VRxDReGoNxGSR
Jul 15, 2001 10:16 PM
