stock block lsvtec turbo???
Old Jul 15, 2004 | 02:33 PM
KiNG $h!t's Avatar
Default stock block lsvtec turbo???
are there any people out there running a stock block ls vtec turbo? Now i know running a stock block on just a na setup is risky taking it past stock redline, but would a stock block lsvtec be ok turboed being only took to 7200?
Old Jul 15, 2004 | 02:37 PM
KiNG $h!t's Avatar
oh and the motor would be daily driven and beaten on...
Old Jul 15, 2004 | 03:38 PM
KiNG $h!t's Avatar
bump
Old Jul 15, 2004 | 03:53 PM
HugePistons's Avatar
Default Re: stock block lsvtec turbo??? (this guy 2fast)
Shur my buddy has a hatch with this set up tuned vary consevabley at 10 pound and he had to miss fourth and go into second for it to blow!
Old Jul 15, 2004 | 03:59 PM
Flexmyrex's Avatar
Default Re: stock block lsvtec turbo??? (HugePistons)
my friend is running consistent 12.5's w a stock block/head lsvtec. 12psi untuned.
Old Jul 15, 2004 | 04:09 PM
KiNG $h!t's Avatar
thanx...i know there are more out there please help me out and reply
Old Jul 15, 2004 | 06:02 PM
KiNG $h!t's Avatar
bump
Old Jul 16, 2004 | 09:14 PM
KiNG $h!t's Avatar
bump
Old Jul 17, 2004 | 03:41 PM
KiNG $h!t's Avatar
up
Old Jul 20, 2004 | 11:48 AM
KiNG $h!t's Avatar
damn no one esle out there runs a stock block lsvtec turbo?
Old Jul 21, 2004 | 10:00 AM
Circuit Star-29's Avatar
Default Re: (this guy 2fast)
I had a lsvtec turbo in my ex, well it was a b20vtec. GSR head and I had boost at 13 lbs from a T3/T04s and 8.9:1 cr via JE dishes. I had timing conservetive at -7 in and +3 ex. Well, it leaned out to 14.4 a/f on the dyno during a 3rd gear pull, damn hondata tuner . Anyway, it was running fine before I wanted more power. Redline for the motor was 7100 rpm but I usaully shifted before that in 2nd 3rd gear. it put down 289 hp at 6800 and torque was huge 201 ft lbs at 5300. The torque curve was very flat. Stock bottom end except the slugs. Never ran at the track though. Just don't get to excited when you want more power, I say build it right the first time so you won't have to worry. Good luck.
Old Jul 21, 2004 | 10:05 AM
Default Re: (nathan atwell)
And one more thing, Im all motor now in my teg, and i haven't wanted to go back to turbo. There is way more response than turbo and it won't run as hot. And the oil changes every 800 miles sucks. And the blow off valve just gets annoying after a bit of stop and go traffic. I like the sound my engine makes a 9000. YEs, i like that more.
Old Jul 22, 2004 | 11:09 AM
turboda6's Avatar
read this
http://www.homemadeturbo.com/f...19375
Old Oct 5, 2004 | 07:02 AM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">And one more thing, Im all motor now in my teg, and i haven't wanted to go back to turbo. There is way more response than turbo and it won't run as hot. And the oil changes every 800 miles sucks. And the blow off valve just gets annoying after a bit of stop and go traffic. I like the sound my engine makes a 9000. YEs, i like that more.</TD></TR></TABLE>
Why not run the BOV back into the intake so you dont hear it? I dont know about you but id take making 300whp and running 12's all day at the track for $1500 then making 220whp for alot more....
Old Oct 5, 2004 | 07:36 AM
philipwight's Avatar
Default Re: (civicflnum1)
I had a stock block ls/vtec that made 360hp to the wheels drvien daily and reved her up to 8500 all the time. When i turned it up at the track is when she blew, ran an 11.6 on 3.5 cylinders.
KiNG $h!t
49
Jan 7, 2008 04:39 PM
eddie1681
Jun 19, 2002 09:39 PM
AzN_Flava
Apr 14, 2002 07:35 PM
