States without Emission Testing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">Thanks guys, keep it up!!!
Are you sure about Virgina? I could have sworn they are worst than MD?
I'm pretty sure West Virgina doesn't, but PA does... Anyone know about Delaware?
Positive on Virginia. They have rediculous state inspection, but it doesn't involve plugging in or any 5 gas, it's just a visual.
Certain counties in Wisconsin don't have emission testing. I live in one county, but simply have to say the car is parked in Brown or Jefferson county, and I don't have to do squat. No questions asked either, its great!
There are probably a few more northern counties, since most up north have like .1 person per square mile...
west virginia also requires no sort of emissions inspection. they have a yearly inspection type deal of the whole car. but nothing emissions related. i personally have seen a WV state inspection and it involves nothing other than a check of the general lights, turn signals, tire tread, and brake pads. they didnt look at any sort of exhaust or check for a cat. i just moved here and used to live in maryland. but like the OP stated, i also got the 2 year waiver deal because my car was too low to fit onto the rollers. i have heard that maryland is soon going to install in floor rollers so that all cars can fit. but they have been saying that around here for a few years. who knows if they will actually get around to doing it.
No emission testing here in canada.
You can get a mecanical inspection but your car need to look like a dump.
I managed to get a mecanical inspection with my 91 accord winter beater ...
as stated above, New york has no emissions testing. 96+ vehicles are required to be scanned through the obd2 port. but 95 an older only require a visual emissions inspection (is the cat there? pass!).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">Can anyone tell me if Texas has emission testing? I'm thinking about moving there next year or so.</TD></TR></TABLE>come on over rick. austin is booming with all kinds of work. in san antonio texas they charge $12.75 for an inspection. all you do is press your brakes, honk your horn, put your blinkers and call it a day. if you have limo tint, just go to the local mom and pop shop and slip the old man a $20. in austin they make you do emisions. i live in austin but register my cars in san antonio.
I passed last time I had to do an emissions test, but fortunately not an issue now. obd1 cars are not also exempt from testing... which is another bonus to having a 1995.
oh edit: sorry this is in missouri btw.
Modified by twkdCD595 at 12:41 PM 7/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivan93egreppin210 »</TD></TR><TR><TD CLASS="quote">come on over rick. austin is booming with all kinds of work. in san antonio texas they charge $12.75 for an inspection. all you do is press your brakes, honk your horn, put your blinkers and call it a day. if you have limo tint, just go to the local mom and pop shop and slip the old man a $20. in austin they make you do emisions. i live in austin but register my cars in san antonio.</TD></TR></TABLE>
Thinking about moving to Houston. Sick and tired of this Cali BS law. I'm going to be smogging my car sometime in September, hopefully for the last time.
Here's what I have so far...
<u>State's Without:</u> MI, KS, IA, NE, HI, NY, WV, TN, OH, ID, IN, ND, SD, WA, MO, ME
<u>State's W/ Certain Counties:</u> MN, TX, NC, OR, FL, WI, SC
<u>State's Requiring:</u> MD, VA, CA, CT, MA
Please correct me if I have any of these in the wrong, or if I forgot one already mentioned!
Anthony
Modified by Mugencrxsir1 at 5:00 AM 7/22/2008
Modified by Mugencrxsir1 at 5:01 AM 7/22/2008
Anthony
Washington requires smog depending on your zip code. OBD-1 and before requires passing a sniffer test at idle and 25mph. Obd-2 they only plug into the port and make sure there is no codes.
Modified by Mugencrxsir1 at 5:01 AM 7/22/2008</TD></TR></TABLE>
ah ****. If possible can anyone find out if houston texas requires you to smog?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludePilot »</TD></TR><TR><TD CLASS="quote">Alabama doesn't</TD></TR></TABLE>
I've seen cars smoking so bad in bama that it fogs up the whole damn road. Cops don't even pull them over.
ah ****. If possible can anyone find out if houston texas requires you to smog?</TD></TR></TABLE>
If I remember I will ask a buddy of mine as he grew up in Dallas, but street raced muscle cars a lot in Houston... But if I had to take a guess I would say yes they require it, but I'll double check for you!
Anthony
Anthony
Updated version, is this correct? Can anyone else verify the remaining states? I'm assuming Alaska is not requiring their 60,000 residents as they are so remote...
State's Without: MI, KS, IA, NE, HI, NY, WV, TN, OH, ID, IN, ND, SD, MO, ME, Al, MS, AR
State's W/ Certain Counties: MN, TX, NC, OR, FL, WI, SC, WA, CO
State's Requiring: MD, VA, CA, CT, MA
Later,
Anthony
Later,
Anthony
Anthony</TD></TR></TABLE>
Thanks man, I really appreciate it.
Yep your **** out of luck, Dallas and Houston are both like MD... They require it every 2 years, but if they are anything like MD if your car is to low to fit on the rollers(obd0) then they just give you a waiver for 2 years... MD does not have visual inspection, just emissions, but the inspection is only done when registering the vehicle...
But my buddy did tell me that if you want to live near Dallas or Houston live out side the surrounding counties and they do not have emissions... So just the major cities/counties in Texas have emissions....
Anthony
</TD></TR></TABLE>Yep your **** out of luck, Dallas and Houston are both like MD... They require it every 2 years, but if they are anything like MD if your car is to low to fit on the rollers(obd0) then they just give you a waiver for 2 years... MD does not have visual inspection, just emissions, but the inspection is only done when registering the vehicle...
Anthony
