Which Standalone, Engine Management should I run??
Old Jun 23, 2002 | 04:09 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Which Standalone, Engine Management should I run??
I am trying to get my stand alone or engine management this week. I was wondering which one should I run. Does anyone have any opinions and links would be helpful as well. Thankz
Old Jun 23, 2002 | 04:13 PM
Sonny's Avatar
Default Re: Which Standalone, Engine Management should I run?? (Civicdrgrcr)
If you've never used engine management before and/or plan on having someone else tune your car, Hondata Stage 2B + datalogging is plenty.
Sonny
Old Jun 23, 2002 | 04:14 PM
reXem's Avatar
I have been told ZDynes is very good but I think it only for OBD0 and OBD1 isn't it? or is it just OBD0? Plus it is about 100 bucks less than Hondatas fully programmable isn't it? I think for Rex I will be going ZDyne
Old Jun 23, 2002 | 05:03 PM
FBP Si 2000's Avatar
Default Re: Which Standalone, Engine Management should I run?? (Sonny)
Sonny
That's what I'm doing, minus the datalogging.
Old Jun 23, 2002 | 05:28 PM
moo's Avatar
moo
i have accel dfi and efi pms for sell. if you interested.
Old Jun 23, 2002 | 06:12 PM
tonydatyga's Avatar
Default Re: Which Standalone, Engine Management should I run?? (FBP Si 2000)
datalogging gives me something to do on rainy days
<< out of crack
Old Jun 23, 2002 | 06:13 PM
ninesecrx's Avatar
Default Re: Which Standalone, Engine Management should I run?? (tonydatyga)
I love carbs....
Old Jun 23, 2002 | 07:16 PM
paulzy's Avatar
Default Re: Which Standalone, Engine Management should I run?? (ninesecrx)
I have a haltech E6K with a plug and play interface box for OBD1...
plugs into the stock honda harness and uses all factory honda sensors. Comes with everything including base maps and some turbo maps...
I'm askin 1050 shipped if you're interested.
Old Jun 23, 2002 | 07:27 PM
2K_TEG's Avatar
Default Re: Which Standalone, Engine Management should I run?? (Slow_ass_4dr)
If you have an LS, I have an ECU already desoldered for Hondata. See sig!! I went with the AEM EMS.
Old Jun 23, 2002 | 07:34 PM
Liltrix's Avatar
Accel DFI Gen 7.
Old Jun 23, 2002 | 08:02 PM
ekb18c's Avatar
Default Re: Which Standalone, Engine Management should I run?? (Liltrix)
Accel DFI Gen 7.
Same here!! However Hondata is a very good system also. It's the bang for the buck with very little modifactions.
Old Jun 23, 2002 | 08:10 PM
SlowB16's Avatar
Accel DFI Gen 7.
how hard is the accel to wire up and tune?? I am assuming harder than the Hondata right?
Old Jun 23, 2002 | 08:25 PM
PrecisionH23a's Avatar
I have researched the hell out of this topic and i just decided the hondata was overall best suited my needs. You need to determine what you are looking for and how much time you are willing to spend to get the unit tuned properly. There has been NUMEROUS posts on this topic, try this one thread from a while ago https://honda-tech.com/zerothread?id=181611. another thing we need to know is what type of boost you will be running, fuel mods, motor, as well as expected hp.
Old Jun 23, 2002 | 09:24 PM
Default Re: Which Standalone, Engine Management should I run?? (GudeH23a)
How many people here are running hondata? How many people are running stage 3 and how many people are running stage2.
Old Jun 23, 2002 | 10:34 PM
I will be running stage 2b soon enough.
Old Jun 23, 2002 | 11:17 PM
austrian type-R's Avatar
When a pro does the programming job, take the brand what your tuner knows best of.
The best systems is only as good as the user.
Old Jun 24, 2002 | 12:01 AM
ion_four's Avatar
ninesecrx, what's your set-up? Is it a blowthrough turbo carb, or are these two different things? heh
Old Jun 25, 2002 | 06:56 PM
tonydatyga's Avatar
A hondata 2b+boost will suit you fine compared to your current setup. There are plenty of good hondata tuners in the dc metro area and a couple of outstanding ones. 2b/boost should also be among the cheapest standalone solutions that will net you the functions you want. if you want to spend $$ you can get a 3b that will add drag launch contol via programmable redline as well as full throttle shifting. But then you would be getting into the ballpark of other brands of standalones...
edit: jsut read austrianR's post... He's got a really good point. If you got a shop you like, ask them what they can do well and consider it
[Modified by tonydatyga, 10:57 PM 6/25/2002]
Old Jun 25, 2002 | 06:57 PM
AlphaKennyWun's Avatar
Default Re: Which Standalone, Engine Management should I run?? (austrian type-R)
Old Jun 25, 2002 | 07:06 PM
bigTom's Avatar
Accel DFI Gen 7.
jk
Old Jun 25, 2002 | 08:04 PM
integra-modder's Avatar
Default Re: Which Standalone, Engine Management should I run?? (ek9t)
how hard is the AEM EMS to learn to use as your first system...?
MikesArmy
Mar 10, 2006 04:47 AM
egg
Apr 22, 2003 02:37 PM
spookhatch24
Feb 25, 2003 09:48 AM
Ruby Civic
Sep 23, 2002 05:02 AM
FOrSfEd
12
May 9, 2002 11:45 AM
