Stalls while driving HELP!
Old Mar 4, 2005 | 09:03 PM
jakfrost84's Avatar
Default Stalls while driving HELP!
So for about 3 months my car has been driving fine. No problems. Just last week I was driving and the car stalls. So i pull off and try to start and it won't start. 15 minutes later i try and startrs right up. This happened a few times real spratic and while im driving. Just last night i Was on my way home frome work and it did it again. I pulled a wire and grounded it to check for spark. The first crank didn't start no spark the "bam" spark and started.
I searched and searched and tried and tested (map, tps, Iacv and all grounds) No luck. Here is my current setup
d16z6 turbo
Msd External coil
Voltage clamp on map sensor
255lph Fuel pump
12:1 vortech fmu
Again, everything was fine for 3 months. PLEASE HELP!
Old Mar 4, 2005 | 09:14 PM
Bspec18's Avatar
Default Re: Stalls while driving HELP! (jakfrost84)
Check your coil, cap and rotor.... thats my best advice i can give you right now...
Old Mar 4, 2005 | 09:21 PM
buckfittyone's Avatar
Default Re: Stalls while driving HELP! (Bspec18)
yup check that distributor,before it cuts off on you for good when your far from home
Old Mar 4, 2005 | 09:52 PM
BoOsTeD C1's Avatar
As the previous guys stated to check the coil or could be ignitor...I had same problem not to long ago and it was my coil that went out on me.
Old Mar 4, 2005 | 10:31 PM
zx6rh22's Avatar
Default Re: (VTEC_pWrD_CiViC)
seems im not the only person. My problem was the damn ignition distributor, like others have said, get that shiet replaced!!!
Old Mar 4, 2005 | 10:32 PM
PrettyLude's Avatar
might be related to the main relay?
Old Mar 5, 2005 | 05:27 AM
jakfrost84's Avatar
BUt why sparaticly? The ignitor or coil doesn't just go bad? Also could it have something to do with the external coil? I am going this weeekend to get a new ignitor just wondering if i should buy a new external coil too. Thanks for your help guys.
And what did u mean buy the main relay?
Old Mar 5, 2005 | 08:25 AM
dustin's Avatar
Try replacing the ignitor. They do wacky things when heat cycled.
Old Mar 5, 2005 | 10:27 PM
PrettyLude's Avatar
Default Re: Stalls while driving HELP! (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Try replacing the ignitor. They do wacky things when heat cycled.</TD></TR></TABLE>
very true
jspeedy
Mar 31, 2010 01:25 AM
jspeedy
Mar 29, 2010 06:34 PM
tgibson
10
Feb 10, 2010 04:17 AM
dc2gsr96
Jan 18, 2010 11:15 AM
94_CRVtec
Jan 6, 2005 11:48 AM
