Squires Turbo Systems
Old Oct 6, 2004 | 07:35 AM
  #26
EJ1 wilcox's Avatar
Default Re: (beeseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beeseries &raquo;</TD></TR><TR><TD CLASS="quote">EJ1, have you ever seen any dyno numbers for this ITR?</TD></TR></TABLE>
Nope, I haven't even seen this ITR in person. It hasn't been there when I've gone...
Next time I drop by I'll ask them about it though, maybe I can snap some more pics of it!
Old Oct 6, 2004 | 07:42 AM
  #27
Nobody Special's Avatar
Default Re: (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">That has got to be the dumbest designs. You do have enough room and puttin in all that piping just causes more lag. Also if you go over a bumb or anything that would occupy that space without the turbo, it would ruin your $4000 piece of ****. Not worth it.</TD></TR></TABLE>
Old Oct 6, 2004 | 07:55 AM
  #28
mchuang's Avatar
I have already seen that setup in person. It was on a dodge viper though. the viper had 2 godzilla bovs and also he had a front mount intercooler. The charge pipes ran like a normal viper exhaust the changed direction towards the bottom of the rear.
Old Oct 6, 2004 | 07:59 AM
  #29
_entropy's Avatar
Default Re: (mchuang)
The reason they have so little lag on LT1's is because they're using small (&lt;60MM) turbos, with .68 or .58 A/R exhaust housings, effectively killing flow when you start making any kind of horse power. Stock truck looking for some cheap extra power, build a setup like that yourself. For a honda where you can buy a good turbo manifold for 300 bucks, don't waste your time. You'll spend more money on a good header trying to make the turbo spool quicker then you would doing a proper turbo setup.
Old Oct 6, 2004 | 03:10 PM
  #30
Blackack26's Avatar
Default Re: (@lbert)
They talk about everything running cooler.... I thought you wanted the exhaust gases to be as hot as possible when entering the turbine?
Old Oct 6, 2004 | 04:11 PM
  #31
Chip's Avatar
Default Re: (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">They talk about everything running cooler.... I thought you wanted the exhaust gases to be as hot as possible when entering the turbine? </TD></TR></TABLE>
You do. Why do you think people try to make the manifold as short as possible, or ceramic coating it to hold heat in? Heat = energy. Energy powers the turbo. You have more energy, you spool the turbo quicker. They band-aid this with smaller exhaust housings and wheels. I can tell you from personal experience after driving an STS equipped car I was not impressed, compared to a conventionally installed turbo.
Old Oct 6, 2004 | 10:23 PM
  #32
beeseries's Avatar
Default Re: (Chip)
Which did you drive?
Old Oct 7, 2004 | 12:08 PM
  #33
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beeseries &raquo;</TD></TR><TR><TD CLASS="quote">Which did you drive?</TD></TR></TABLE>
I drove an LS1 camaro with a GT67.
Old Oct 7, 2004 | 12:27 PM
  #34
92BlackSi's Avatar
you could steal that setup in 60 seconds!!
Old Oct 7, 2004 | 12:30 PM
  #35
Vanilla Ic3's Avatar
Default Re: (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">you could steal that setup in 60 seconds!!</TD></TR></TABLE>
On a lifted full size truck you wouldn't even have to get your shirt dirty.
Old Feb 8, 2005 | 07:47 PM
  #36
itr1244's Avatar
Default Re: (TurboSmart)
it's pretty funny..
  #37
itr1244's Avatar
it's pretty funny..
Old Feb 8, 2005 | 07:48 PM
  #38
wantboost's Avatar
Who is Mr Robot?
Default Re: (itr1244)
ok...?
Old Feb 8, 2005 | 07:59 PM
  #39
AspectIndustries's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">no, no prototyoe, thats the retail kit. they did an article in turbo magazine on them a couple months ago. i'll search through my massive stack (couple hundred) of magazines and see if i can find it. </TD></TR></TABLE>
They had it on their site.
http://i.b5z.net/i/u/1473169/f/Press/STS_THP.pdf
D.O.C.-Race
Welding / Fabrication
Sep 16, 2011 09:35 AM
figor
Jan 20, 2008 04:49 PM
GreddyTegra
Aug 8, 2006 07:33 PM
Arturbo
Apr 29, 2002 12:15 PM
