sputtering under boost and @ WOT
yeah, i'm sure i'm not hitting boost cut. i never had this problem, soo boost cut can't be it. just started to happen out of the blue, just when i got my air/fuel ratio flat under all rpms, i start to get this problem.
Hey, I had the exact same problem and replaced plugs, wires, cap, rotor, ignitor, coil, and dist. Turns out the rotor I had bought (not from Honda) was not insulated on the sides of the blade. When I switched to a new one, it would run like normal for a few days, but then eat it. Switching back to an OEM insulated rotor fixed ALL hesitation. HTH Please please try it out if your not using an OEM rotor.
it's my plug wires guys!
the heat killed em. need a heat shield and some maybe wrap the down pipe now. feels soo good again. never thought the wires would gp out like that. seen some where on the net, they said the exact problems i was having.
