Sputtering at 8k
Old 11-04-2012, 08:34 AM
Chuonthis069's Avatar
Default Sputtering at 8k
I just redid my head and put it back on my car while tunning the car I noticed that I can't get pass 8k RPM.
Here is my set up
00 ITR
Rods n pistons Gt35 turbo 750cc injectors AEM EMS
Could this problem be with my ITR cams?
Please help
Old 11-04-2012, 08:39 AM
mtber's Avatar
Default Re: Sputtering at 8k
Could be anything.
Start by making sure the ignition timing is properly set & air fuel ratios are not too rich or lean when this issue is occuring.
Then try new plugs gapped down to the proper gap.
Then try another distributor/coil assembly etc.
Old 11-04-2012, 08:44 AM
Turbo-LS's Avatar
Start at the basics, did you sync the distributor? Did you put new plugs and not properly gap them down?
Old 11-05-2012, 05:31 PM
wunfstgsr's Avatar
spark gap?
Old 11-05-2012, 08:19 PM
Checked all the basics new wires new plugs gap at 20
Cap and rotor
My tuner told me he has seen this before so he replaced my ITR cams with B16 cams and now it's smooth all the way. I was able to get 396hp at 12pounds of boost on pump gas
Old 11-06-2012, 06:42 AM
kyden's Avatar
that does not sound right with the cams.
Old 11-06-2012, 06:57 AM
mayfly's Avatar
agreed. those cams shouldn't give you any issues like that.
Boyle.R
26
11-09-2012 03:09 PM
ACrite3404
03-25-2008 04:29 PM
Cpt Ben
03-22-2008 09:39 PM
Global688
11-30-2007 07:34 AM
baruba
09-27-2003 03:43 PM
Quick Reply: Sputtering at 8k
