Sprung disk
Old Jan 1, 2007 | 09:46 AM
vti2's Avatar
Default Sprung disk
Wich is stongest that i can get and where can buy it?
Old Jan 2, 2007 | 01:21 PM
vti2's Avatar
Default Re: Sprung disk (vti2)
nobody?
Old Jan 2, 2007 | 01:38 PM
xsi-t's Avatar
im running act's new 6 puck sprung... i believe its not just the clutch that handles HP but the pressure plate.. wich i use is the hdxx
Old Jan 2, 2007 | 02:12 PM
Mugencrxsir1's Avatar
Default Re: (xsi-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti2 &raquo;</TD></TR><TR><TD CLASS="quote">Wich is stongest that i can get and where can buy it?</TD></TR></TABLE>
What pressure plate are you running? The pressure plate is where your strength and grip really comes from, I'm a fan of ACT as well. A lot of people are running an ACT pressure plate with Action or Centerforce 6 puck discs. I personally like the ACT 6 puck sprung disc, along with ACT's extreme pressure plate. It's all personal preference!
Old Jan 2, 2007 | 04:42 PM
vti2's Avatar
Default Re: (Mugencrxsir1)
pp ist an exedy stage2
Old Jan 2, 2007 | 06:20 PM
b18sihatch's Avatar
the holding force will come from your pressure plate.
ie: HD xtreme PP hdxx ect
the holding capacity increases with the different pressure plates.
as far as discs most are the same with different pad materials used
Old Jan 2, 2007 | 06:29 PM
Default Re: (vti2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti2 &raquo;</TD></TR><TR><TD CLASS="quote">pp ist an exedy stage2</TD></TR></TABLE>
What are you planning on doing? Are you uping the HP via turbo/supercharger? If so I would get a whole clutch kit or just a stronger/newer pressure plate. You are going to need more holding power, and I like ACT because their clutches are under-rated and can hold a lot more then rated. To answer your question the ACT sprung 6 puck and/or Action's MS 6 puck sprung disc are both great discs. We need more info to further guide you...........
Old Jan 2, 2007 | 06:55 PM
mike93eh2's Avatar
action sprung 6 puck here.
Old Jan 3, 2007 | 03:49 AM
vti2's Avatar
Default Re: (mike93eh2)
It schould hold 500+whp. It is mostly street car, it will only see the track 5 times a year.
It is a fully build b16 with a GT3767S on it.
boostedsc61
Aug 24, 2006 12:43 PM
BoOsTiN Dc2
Apr 2, 2006 02:29 PM
