spool up times
Old Sep 9, 2003 | 11:15 AM
Mr. Softee's Avatar
Default spool up times
post em!
equal length mani, 3" dp, 10:1, t3/t4 57 trim .63a/r stage V wheel, 2.5" ic piping everywhere
4100ishRPM
Old Sep 9, 2003 | 11:33 AM
quikB18B's Avatar
Default Re: spool up times (94goldjungsr)
d16, precision sc63, 8.5.1 compression, 7 psi, timing retarded to 12, = it never spools
J/k Presicion sc34, 2.5-3" downpipe, 3" exhaust, .45 bar about 3900-4000 ish
Old Sep 9, 2003 | 11:55 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: spool up times (quikB18B)
Stock B16A, 2.5 inch DownPipe, 2.5 inch Test pipe, 2.25 inch Exhuast.
Garret T3/T4, .60comp, .48 A/R.
Full boost at 3500rpm.
Old Sep 9, 2003 | 11:59 AM
ELSpool's Avatar
D16Y8
T3/T04E 57 Trim wheel, .48 exhaust
2.5 DP & exhaust, not cats, or res.
10 psi at 4100rpm
Old Sep 9, 2003 | 12:10 PM
InTeGrA B18b1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">post em!
4100ishRPM</TD></TR></TABLE>
i think yours should spool fast than that. my ls t3/t4 57 trim .60 .63 full boost at 4500+ with a open 2.5 dp.
Old Sep 9, 2003 | 12:51 PM
hawjdude's Avatar
Default Re: spool up times (InTeGrA B18b1)
Seeing full boost at 4k.
t3/t4 .60
2.5 dp
Old Sep 9, 2003 | 03:51 PM
shermanyang's Avatar
Default Re: spool up times (hawjdude)
MPRacing equal length mani, T3T04E snail .63 a/r .60 compressor .57 trim, 2.5" dp, 2.25" (choking...) exhaust
spools at 3.5 full boost by 4.5(15 psi)
Modified by shermanyang at 5:15 AM 9/10/2003
Old Sep 9, 2003 | 04:07 PM
DIRep972's Avatar
Smarter than you
when u guys say "it spools at" or "full boost at" you need to specify the boost level. spool up to 10psi will probably take 1000 less rpm then spool up to 20psi.
anyways heres mine.
Full-Race, SC34, stock LS, 3" downpipe, skunk 2 IM.
8psi @ 4000.
13psi @ 4500.
Old Sep 9, 2003 | 04:10 PM
danl's Avatar
Banned
Default Re: spool up times (DIRep972)
Meh, not a honda but......
small 16g, 2.0L 4g63.......24 psi by 2800 rpm's with cutout open. Its a torque then die kinda powerband
Old Sep 9, 2003 | 04:48 PM
scatuli's Avatar
Default Re: spool up times (danl)
b18a1 stock motor t3t4 57 trim .63 ar housing 2.5 in intake piping the whole way through and 2.5 in exhaust all the way back
i am spooled at 8 psi by 3700
Old Sep 9, 2003 | 05:05 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">Meh, not a honda but......
small 16g, 2.0L 4g63.......24 psi by 2800 rpm's with cutout open. Its a torque then die kinda powerband </TD></TR></TABLE>
My setup spools like yours. lots of power early then kinda just flatens out up top. Do you find your car is faster if you shift short of redline (which is a very un-honda thing to do BTW) It a pain to drive, hoping a bigger, not stock, exhaust will help
Old Sep 9, 2003 | 05:22 PM
danl's Avatar
Banned
Default Re: spool up times (Bailhatch)
I shift first at teh rev limiter, second at 6500, and run third through the traps (7500 rpm's or so). It gets to 6000rpm's quick, but dies after that. My traps suck IMO.
Old Sep 9, 2003 | 07:11 PM
QCKGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">I shift first at teh rev limiter, second at 6500, and run third through the traps (7500 rpm's or so). It gets to 6000rpm's quick, but dies after that. My traps suck IMO.</TD></TR></TABLE>
need bigger back housing ..
Old Sep 9, 2003 | 07:23 PM
DsMWookie's Avatar
12lbs
d16a6
3.5k
should be faster but dime soze whole in charge piping just found today fixing.
2.5" exhaust and dp
Old Sep 9, 2003 | 07:56 PM
TotalJDM.com's Avatar
Default Re: spool up times (FMX)
My friend showed me the dyno chart of a t3/60-1... nothig till it hit 5500rpm, but the car did 550whp+
Seeing that chart always gives me a little smile, must be good feeling once it spools up!!!
Andre
VtecAdil
Apr 19, 2005 06:51 AM
Prelude91siT
Oct 29, 2004 04:59 PM
boosted jetta
Oct 20, 2003 07:53 AM
bottlefedb18c1
Jan 10, 2003 07:17 AM
