sparkplug wire blowing/popping off under boost?
well, i've been boosted for about 4-5 months and in the last couple months, i've noticed that the sparkplug wire on top of my valve cover (the part that connects to the sparkplug) keeps popping off under boost. my spark plug still fires because it doesn't get completely blown off but just sits there still providing current. i read somewhere that this happens because of the high crankcase pressure commonly found in honda motors. what can i do to fix this? i was thinking maybe somekind of different pcv setup like the dsm's?
[Modified by theory48, 9:47 PM 4/2/2003]
1 Post
Re: sparkplug wire blowing/popping off under boost? (theory48)
put one of those rice er riffic filters on the top of the valve cover(the large bung that goes to the stock intake). i had the same problem, and this fixed it. I primer-blacked mine out though
Re: sparkplug wire blowing/popping off under boost? (Tinker219)
well, i already have a breather filter on my valve cover so i don't think that's the problem. how about if i run a vacuum line from the valve cover to the intake side of the compressor?
There should be no pressure leaking through the threads of your spark plug if it is tightened peoperly. Double check to make sure you don't have any stripped threads and maybe replace the wire that keeps falling of, the connector inside may be worn out, regardless your plug wires should not be popping off like that.
Re: sparkplug wire blowing/popping off under boost? (Diego Boost)
really? i've noticed that alot of the complete turbo kits have a bung to attach a vacuum line on the intake pipe that goes to the compressor.
i know MSDs are knwo for doing that , mine did , i sent em back and got new ones and fine now .
Re: sparkplug wire blowing/popping off under boost? (itr206)
I've never had that problem with factory honda wires, experienced it several times
with aftermarket wires.
The pressure isn't going past the threads on the spark plug... it's escaping past the the seals that on the inside (backside) of the valve cover. There are 4 rubber seals that keep oil from going into your spark plug channels that should be replaced whenever you replace the valve cover gasket. Check those... however, if those were leaking you'd see a little bit of oil on your spark plug boots also. If you're not seeing this, it's most likely the plug wire just comming off from viabrations. Do this... take the spark plug wire off the plug and look into the bottom of it. See that brass connector that clamps onto the top of the spark plug. Use a pair of needle-nose pliars and slightly (SLIGHTLY!) pinch it. Now when the plug engages on the spark plug it'll hold a lot snugger. If you pinch it too much you'll have problem getting the wire back onto the plug. Don't panic, just pull it back out and spread the brass fitting a little bit.
If this is to intensive and you want to spend money, get some new wire... stocks are fine... because this is happening because you're wires are prolly old and the engage clip is worn out.
BTW, if you run a hose from the valve cover to the intake tube run it after your air filter, but before the turbo. If you do it after the turbo (i.e. compression side of pipe) you'll have some nice oil control problems to deal with and enjoy. Also, running a ricer boy filter on top of your valve cover isn't a good idea either. You're not sucking air into the valve cover through that point, you're sucking it out. Putting a filter on that point just f's up your PVC system.
Enjoy!
Re: sparkplug wire blowing/popping off under boost? (JRSCCivic98)
Enjoy!
Enjoy!
spencer00si
09-06-2002 01:46 PM
