Which Spark plugs for 460whp+
hey H-T.
i have a built ls/vtec motor making the said power. im currently running BKR7E spark plugs. i feel i need colder range. are there any you guys recommend for 500+ hp? im upping the boost.
i did research already,
came up with these two.
- R5672A-8 7173
- R5671A-8 4554
what are the difference between these two?
- R5672A-8 7173
- R5671A-8 4554
1. It gets hot here where i live. through out the summer (June-september) between (80-100f)
2. through out all of the other seasons. IE: Winter, Fall, Spring. (october-may) it never falls colder than 45F
Only if your EGTs are getting out of hand outside of 1600F at WOT is a "colder" plug like an 8 needed. You should be fine with 7 heat range, regardless of outside ambient temp, unless the tuner has not accounted for it in their calibration of the car
Casey
Mar 19, 2002 07:00 PM
