need help on spark plug heat range and gap?
Old May 21, 2006 | 08:39 AM
eg:R's Avatar
Default need help on spark plug heat range and gap?
im running 6 degree heat range plugs and gap at .28. just wondering if this is the right heat range and gap for my setup. pushing 400hp @ 17psi. i'm currently running the cheap v-power ngk plugs. planning to go get some iridium plugs and just want to know if i should get the same head range or difference one.
Old May 21, 2006 | 08:44 AM
RTW DC2R's Avatar
Default Re: need help on spark plug heat range and gap? (eg:R)
from what Ive seen, its best to stay away from the iridium plugs. most people seem to run coppers with heat range 7. maybe even colder if running race gas.
search the archives there is a ton of plug information
Old May 21, 2006 | 08:46 AM
SOHC_MShue's Avatar
stick with the v power plugs. Dont get that iridium ****. I would def go colder on the heatrange though for that power level.
Old May 21, 2006 | 08:53 AM
eg:R's Avatar
how do i know which plugs are coppers? do you have a part # for that. is 6 heat range ok for 400hp range? 7 heat range??
Modified by eg:R at 7:16 PM 5/21/2006
b00stedbyFastrax
Jun 9, 2008 11:22 AM
teh leet civic
Oct 12, 2004 08:47 PM
ALLMOTOR18
Sep 10, 2002 03:05 PM
Casey
Mar 19, 2002 07:00 PM
mattmw88
Feb 22, 2002 07:54 AM
