spark plug gap??
Old Apr 5, 2006 | 02:54 PM
92LsTegra's Avatar
Default spark plug gap??
had them at .045 and had problems, called a performance shop and they said gap to .020?? thats close to no gap. the car is a 92 integra t3t4 running about 6-7 psi. reason im asking is cuz im getting a miss every now and then and i would just like to know my plugs are gapped correctly. spec stock is .032. anyone?
Old Apr 5, 2006 | 03:00 PM
Soccerking3000's Avatar
Default Re: spark plug gap?? (92LsTegra)
.03 should be good
Old Apr 5, 2006 | 03:19 PM
93turbo16's Avatar
I usually go anywhere between .025-.028
But on that boost setting, .028 to .030 should be ok. If not gap it smaller. You want the biggest gap you can get without having problems.
Old Apr 18, 2006 | 05:57 PM
PHDZINE's Avatar
Decrease the gap by .002 at a time and try them out to see what works best without missing and you want the biggest gap without any misses. For 6-7 psi I would say .030-.032 should be ok. You might want to check your timing as well just to make sure your timing is ok. By the way I gap mine at .022 for 40 PSI so I would say .020 would be way to low and I think stock spec. is .044 not .032 but I might be wrong.
Old Apr 18, 2006 | 06:06 PM
Dunc's Avatar
BCICAN
.020 is a little over kill. Do .028 and you'll be good. I had the same thing (ignitino breaking up when they were at .038 so I put them to .028 and it was running smooth.
Old Apr 18, 2006 | 06:34 PM
Flexmyrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LsTegra &raquo;</TD></TR><TR><TD CLASS="quote">had them at .045 and had problems, called a performance shop and they said gap to .020?? thats close to no gap. the car is a 92 integra t3t4 running about 6-7 psi. reason im asking is cuz im getting a miss every now and then and i would just like to know my plugs are gapped correctly. spec stock is .032. anyone?</TD></TR></TABLE>
i wouldnt gap them any less than .027-.028. Remember if you gap them too close the ground electrode will prevent/block the spark from using all of its energy to ignite the mixture. If its still breaking up and its not due to fouled plugs, id look into the wires, coil or into buying an aftermarket ignition system to increase your secondary coil output.
crashsvg
Engine Management and Tuning
Oct 14, 2011 09:26 AM
RubenPrelude
Jun 9, 2007 07:13 AM
mrrugsr
Apr 12, 2006 12:04 PM
the.hamburglar
Jul 7, 2005 09:36 PM
swissturbo
Jun 14, 2002 11:33 PM
