Someone save my cars life. Im about to take out the hammer.
I have had it with this car. Ive put so much work into it this year and Im running into problem after problem. Ive run out of patience. Im gonna destroy the POS soon.
Im stumped. I have absolutely no oil pressure. Its a rebuilt d16z6. The oil pump is a brand new OEM pump. I tried turning it over with no fuel to build pressure, nothing. So I poured some oil down my feed line, nothing. Finally I took the cap out of the oil pump and pumped oil in. Still nothing. WTF!
Im cranking about 5 seconds at a time and there is no sign of oil pressure. Im afraid of toasting my bearing at this point.
WTF IS GOING ON!?!??!
Re: Someone save my cars life. Im about to take out the hammer. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Dude just start it. If it doesnt build pressure in the first 5 secs shut it down.</TD></TR></TABLE>
Thats what I had to do. It wasnt building pressure cranking for 5 secs. I cranked it up and within like 2 secs it had full pressure
Im not even getting a drop of oil coming out of my feed line! At this point Id say starting it is the last thing I want to do... :S. Im just terrified of killing it.
Re: (OrangeBoost)
pull your oil filter and see if you have any oil. If your aren't getting oil pressure, depending on where you put your pressure guage, you won't have any oil in your feed line either, for an obvious reason.
Re: (OrangeBoost)
Start it up, and like muckman said, if you dont have pressure in 5 seconds, shut it down. 5 seconds is a long time but I generally dont see pressure till about 3 seconds after I start my car because if where I have my sensor placed.
Re: (Blaze45)
We've all been in this boat. You just have to man up and start it. I was so scared I just about crapped my pants when I started mine for the first time.
By the way, cranking it over isn't supposed to actually build pressure - it's supposed to cut down on the time it takes to build pressure once you actually start the motor. I've never seen pressure register by just cranking it over.
Re: Someone save my cars life. Im about to take out the hammer. (OrangeBoost)
well you should be able to get some pressure just cranking it...after a number of cranks it will produce pressure in the feed line for the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost »</TD></TR><TR><TD CLASS="quote">Even with a finger over the open end of the feedline there isnt even a pulsing.</TD></TR></TABLE>
strart the damn thing......cranking it does not build any pressure when its cold.......especially when its a fresh engine......
Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">
strart the damn thing......cranking it does not build any pressure when its cold.......especially when its a fresh engine......</TD></TR></TABLE>
Or just stay scared and have a nice paper weight
Re: (warrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warrick »</TD></TR><TR><TD CLASS="quote">check the oil filter? maybe replace it</TD></TR></TABLE>
Its new...I wouldnt put an old filter on a new engine.
I guess Ill just have to start it like everyone is saying.
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">it may be a dumb question, but do you have oil in the car?</TD></TR></TABLE>
hahaha. That's the answer! People are such pansies with their cars. I had a 88 prelude that wouldn't die so I drained all the oil out of it and drove it on the hottest day of the year and it still wouldn't die. I popped the clutch from 8k 5 times and still went. I finally just gave up and drove it to the junkyard. Now go start your ******* car!
Ahh **** now Ive just had someone tell me that they got a good amount of oil coming out their feed line on their last three engine while cold cranking. That does not make me feel any more confident about just starting it up.
It took me about a min. of cranking on a new motor for the oil light to go off ( i didn't have a pressure gauge) .. then once it went out i just hooked up the dizzy, fuel and started it .. runs fine now
Re: Someone save my cars life. Im about to take out the hammer. (LSVtechnologyturboboost)
Just start it already! If you dont get oil pressure in 5 seconds, then shut it off. I highly doubt that running it for that amount of time will toast your engine or your turbo. Did you take the valve cover and filter off and crank it to see if oil spews all over the place yet?
