Someone please help me,lol
Old May 21, 2007 | 07:31 AM
jfruauff's Avatar
Default Someone please help me,lol
OK My car is going crazy. I have a 96 civic with a 95 gsr swap, turbo kit, ect.
Ok one minute the car will drive fine and boost just fine. The next it wont boost at all just hit 0 and make a wierd air sound. Not touching anything the car will all of a sudden start boosting again. There is no set time that it does it. This moring i went to work and it wouldnt boost and when i got off it boosted fine.
What u guys think all i can think is maybe wga is going bad and sticking. I can hear it spool but no boost.
Old May 21, 2007 | 07:45 AM
Joseph Davis's Avatar
Default Re: Someone please help me,lol (jfruauff)
Wastegate or BOV fuckage. Sounds like BOV if you hear a whine... which is bad, the turbo is spinning to infinity and beyond and will kill itself in short order.
I'd spray your BOV down with WD40 or the like to flush out and corrosion, then dry it completely and use something that is an actual lubricant like white lithium spray/grease. WD40 is actually kerosene and evaporates.
Old May 21, 2007 | 08:01 AM
92LSVTEC's Avatar
what wastegate/BOV are you running?
Old May 21, 2007 | 09:00 AM
jfruauff's Avatar
Default Re: Someone please help me,lol (92LSVTEC)
greddy bov
turbonetic deltagate wga
I am gonna say wga then because when it happens i still hear a bov just very fain so ill change wga and see
Old May 22, 2007 | 07:25 AM
jfruauff's Avatar
OK well changed the wastegate and still having the same problem. Really dont think its the bov because i still hear it whistleing when i get off gas.
Guys i am lost
Old May 22, 2007 | 08:12 AM
jfruauff's Avatar
OK I just went out and was looking for something lose or something that would make me not boost at times. Car wasnt bosting when i got home and when i turbed it on still no boost. Went to engine and notciced turbo wasnt spinning gave a lil throttle still no spinning. Turned car of and tried to spin by had and it felt jammed turn bladed the opposite way turned easy then would turn both ways. Turn car back on and had boost. This is a freshly rebuilt turbo what could be the problem. The turbo will spin for w while at idle but will stop spinning. Then a lil throttole it will spin again but again will eventually stop. Is this normal. Could i be lacking oil flow. I am using a feed line off a golden eagle sandwich.
Old May 22, 2007 | 11:39 AM
Check that your housings are bolted down, sounds like the wheels are binding against the housing.
Sounds like it's time for the turbo to come off + rebuild, actually.
Old May 22, 2007 | 02:12 PM
jfruauff's Avatar
Default Re: Someone please help me,lol (Joseph Davis)
The turbos freshly rebuilt, everything is tight 200% sure
Old May 22, 2007 | 07:34 PM
Then how come it's randomly sticking?
Turbo needs to come back off for inspection, it probably has some damage.
EJ1 wilcox
Feb 3, 2007 10:32 PM
TEG777
Sep 11, 2005 01:20 PM
Jayboy
May 12, 2005 10:57 PM
Nextelbuddy
Jun 12, 2004 06:39 PM
turboITR#704
Jun 14, 2003 08:36 AM
