Someone clear this up for me vac lines
Old Feb 10, 2005 | 03:28 PM
ebpcivicsi1234's Avatar
Default Someone clear this up for me vac lines
Ok i have searched for some time now and have got 2 different awnsers.
I have a vac manifold,hooking that up to the brake booster line after the check valve.From there iam going to hook up one vac line to my blow off vlave,another vac line to my boost controller,and this is where i get to different ways of doing it..Iam going to run a electronic boost controller so i know the top wastegate port is going to go to the boost controller.Now the bottom where does that go i have seen it goes to the turbo compressor housing(well mine isnt tapped for that)or i have seen it go to a vacuum source..is this right so i just hook the bottom port to my vac manifold..Also i dont have my boost controller yet but isnt there 2 ports that hook up on the boost controller.I plan on getting the avcr..Thanks i know these are newb questions but i wanna make sure i have everything right
Old Feb 10, 2005 | 04:47 PM
PrettyLude's Avatar
i have mine hooked up to the intake manifold
Old Feb 11, 2005 | 05:48 AM
Default Re: (PrettyLude)
up
Old Feb 11, 2005 | 06:12 AM
Muckman's Avatar
Moderator in Chief
Default Re: Someone clear this up for me vac lines (ebpcivicsi1234)
If it cant go to your compressor housing then it can go to your vac manifold. Its all good.
fuegoski
Mar 5, 2013 05:41 PM
2ndchirp
May 24, 2009 08:14 PM
RedEj8
Jun 4, 2006 04:01 PM
RNPoo7
Apr 8, 2005 06:33 AM
importboi22
May 20, 2004 04:43 AM
