Some help on why my car has this problem.
Old Nov 24, 2007 | 06:10 PM
hmongxcuz's Avatar
Default Some help on why my car has this problem.
When I throttle my car, it sputters and then dies/stall out. I cant even get to 3000 RPM without it happening. At times when I stick it into 1st gear it will stall out too. It all started to happen when I installed the adjustable FPR, also one of my pins/wire came out on the ECU but it doesn't throw a CEL. The car is boosted and tuned, it has the right injector size for the power its making.
It shouldn't be the timing since it never happend before.
I think that its when I installed the FPR and turned it up to 45PSI but what can turning the PSI up do?
What do you think is going on?
Can it be the FPR or loose ECU wire?
Any kind of info be helpful.
Modified by hmongxcuz at 7:27 PM 11/24/2007
Old Nov 24, 2007 | 06:59 PM
Sr420Det's Avatar
If it was tuned why did you mess with it?
Old Nov 24, 2007 | 07:02 PM
hmongxcuz's Avatar
Default Re: (Sr420Det)
LOL, what I mess with?
I just changed the stock FPR with a adjustable one (AEM).
Old Nov 24, 2007 | 07:28 PM
GraphiteAccord's Avatar
Default Re: (hmongxcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongxcuz &raquo;</TD></TR><TR><TD CLASS="quote">LOL, what I mess with?
I just changed the stock FPR with a adjustable one (AEM).</TD></TR></TABLE>
you said it was tuned....why did you change things on the tune?
Old Nov 24, 2007 | 07:43 PM
hmongxcuz's Avatar
Default Re: (GraphiteAccord)
Are you saying I cant change to a aftermarket FPR after the car has been tuned? Im sure I can. Its been tune for awhile even before the aftermarket FPR was installed.
So will I need another tune since the stock FPR was 40PSI and now the new one is turned up to 45PSI?
Old Nov 24, 2007 | 07:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongxcuz &raquo;</TD></TR><TR><TD CLASS="quote">Are you saying I cant change to a aftermarket FPR after the car has been tuned? Im sure I can. Its been tune for awhile even before the aftermarket FPR was installed.
So will I need another tune since the stock FPR was 40PSI and now the new one is turned up to 45PSI?</TD></TR></TABLE>
Yes. You changed something related to your tune. So now it needs to be retuned.
Upping the fuel pressure, will also up the amount of fuel going into the engine.
Old Nov 24, 2007 | 08:15 PM
hmongxcuz's Avatar
so the answer is to get another tune since there are more PSI of fuel going into the motor than whats it tune at and is that why my car dies out?
40PSI tuned on turned up to 45PSI = another tune?
Old Nov 25, 2007 | 09:08 AM
coneheadsracing's Avatar
Turn your pressure down to 40 psi, and put the wire back in. It's there for a reason.
Old Nov 25, 2007 | 10:37 AM
hmongxcuz's Avatar
Default Re: (coneheadsracing)
alright let me do that and see.
Old Nov 25, 2007 | 10:55 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">Turn your pressure down to 40 psi, and put the wire back in. It's there for a reason.</TD></TR></TABLE>
TurboCX
Welding / Fabrication
Jun 9, 2008 05:15 PM
98B18C1
Dec 7, 2006 12:02 AM
stockegsix
Jul 28, 2005 06:16 AM
MugenHonda
Jun 26, 2005 12:43 PM
