Need help, having problems running welder
Old May 27, 2008 | 09:35 PM
TurboCX's Avatar
Default Need help, having problems running welder
I bought a Sync. 200 about two years ago and unfortunately never had enough time to use it. I recently had a friend install a 240v single phase and decided to mess around with the welder over the weekend. The welder turns on, but I can't get it to strike an arc. It doesn't do anything, but I do hear the postflow when I release the pedal. Do you guys have any suggestions as to why the welder doesn't strike an arc? Could it be that the 240 single phase wasn't installed properly or a possible grounding problem? Any suggestions? Thank you.
Old May 27, 2008 | 10:05 PM
ROTARY's Avatar
Default Re: Need help, having problems running welder (TurboCX)
hopefully your friend just switched the machine from HF-start to lift-arc or vice versa.
Old May 28, 2008 | 06:23 AM
shortyz21's Avatar
Default Re: Need help, having problems running welder (ROTARY)
its its turned on then its not the power source.
its prolly something screwed with your remote wire... aka pedal
Old May 28, 2008 | 05:57 PM
TurboCX's Avatar
Default Re: Need help, having problems running welder (shortyz21)
Thanks Rotary and Shorty.
Any other ideas? Thanks.
Old May 28, 2008 | 08:37 PM
TurboCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">hopefully your friend just switched the machine from HF-start to lift-arc or vice versa. </TD></TR></TABLE>
My friend didn't touch any of the settings on the machine. When you select the TIG process on the sync. 200, a non contact arc starting method is automatically activated.
Old Jun 9, 2008 | 05:15 PM
rotten's Avatar
What are the settings you're using on it / lights that are on?
I have a Sync 200
Munchnd
Honda CR-V & Element
Nov 6, 2018 09:33 PM
Zornig
Welding / Fabrication
Dec 19, 2006 02:06 PM
Frito1
Honda Motorcycles
Mar 28, 2005 08:47 AM
accordsil2
Audio / Security / Video
Jun 29, 2003 07:10 PM
delsolrmp
11
Jun 12, 2003 08:58 PM
