Some DRAG questions....
I just got my DRAG kit and there are some questions that I have.
1) On the compressor, there is a hole just before the outlet. looks like a screw could go there to block it off. Should it be blocked off? what is it for?
2) I have almost no idea on how to do the vacuum lines for the wastegate. Could someone maybe send me a diagram or some instructions on how to do the vacuum lines for the wastegate? I haven't found any that have been helpful.
3) I know i have to clock the turbo, but do I need to remove the screws on the turbo to move the center peice or just loosen them? The way it looks, I'll have to move the compressor and the center peice. Some tips on how to do this would be helpful.
And that is about it for now. Thanks in advance.
1. thread in a small hose barb to the little hole on the compressor housing and run a vaccuam line to the side port of the wastegate.
2. see #1.
3. just loosing the bolt and you should be able to turn the center piece.
2. see #1.
Flamenco-T
Jan 23, 2007 06:23 PM
turbodan4
Jul 5, 2004 07:55 PM
JustAnotherHonda
Mar 1, 2003 04:34 PM
