solid cel...just boosted.
Old Aug 15, 2006 | 01:33 PM
crx treme's Avatar
Default solid cel...just boosted.
i just got my car on the road today, b16a crx, t3/to4e. i have a basemap from phearable and it runs great, but i have a solid cel. i have a cel shift light with a switch to go from cel to shift light. i either have a solid cel or no cel when the switch is flipped. any ideas?
Old Aug 15, 2006 | 02:42 PM
BB6-213's Avatar
Im pretty sure you have the wiring messed up, or the shift light settings are messed up because a solid cel means ecu failure, and your car would run in limp, and you would notice that, so check your settings, and the wiring.
Old Aug 15, 2006 | 02:52 PM
Tad's Avatar
Tad
so when you jump the service check connector the CEL stays on and doesn't blink at all?
Old Aug 16, 2006 | 08:32 AM
crx treme's Avatar
Default Re: solid cel...just boosted. (crx treme)
even though i have the switch i still have to jump the service connector? i thought thats what the switch was for.
Old Aug 17, 2006 | 09:32 AM
crx treme's Avatar
so what wiring should i be checking? the conversion harness was hooked up correctly, everything was soldered and taped. the ecu is hondata ready, but has a chrome basemap. could that affect something? i cant get tuned with a solid cel.......
Old Aug 17, 2006 | 09:58 AM
blundar's Avatar
contact your tuner. they should be able to help you.
Old Aug 20, 2006 | 01:47 PM
crx treme's Avatar
i found the problem. the ecu is fried. the part that is fried has "q31" next to it. what happened?
Old Aug 20, 2006 | 02:27 PM
crx treme's Avatar
ok i did a lil research and found out that the purge solenoid and iat sensor plugs could be switched. i checked, and the appear to be in the correct positions, i have no canister or purge selenoid. however when i unplug the iat sensor the solid cel goes away. wtf is going on?
red and green wires>>going to iat.
checked resistance on iat sensor and comes up okay....3.9
Freemananana
Jul 14, 2014 10:03 AM
japek
Mar 19, 2010 08:34 PM
JinDIESEL
Sep 24, 2004 02:06 PM
hYpE-R-29
Oct 30, 2003 08:43 AM
