SOHC TURBO VS DOHC TURBO
WHAT UP GUYS I HAVE A GREDDY TURBO KIT I HAVE FOR MY 99 GSR MOTOR, IN MY 92 SI, ALL I NEED IS PIPING FOR THE INTERCOOLER AND TURBO, CAN I USE THE SAME PIPES FROM A SOHC GREDDY TURBO KIT? OR DO I NEED TO BUY PIPING FOR THE MOTOR? (GSR) I FOUND SOME PIPING ON EBAY, BUT ITS FROM A SOHC! WILL THE TURBO FROM A SOHC FIT ON THE SAME MANIFOLD AS THE GSR SETUP? SUM1 HELP!
Re: SOHC TURBO VS DOHC TURBO (GSRHATCH187)
Make your own. It's always cheaper and easier. Walmart has welders (stick) that can get the job done for $89.
Otherwise, your on your own. I don't know anything about buying a piping kit... They are just pipes. Sorry
Re: SOHC TURBO VS DOHC TURBO (Johnyquest)
The SOHC piping won't fit to my knowledge. And as for if youc an use the Greddy SOHC turbo(15G) on the Greddy DOHC manifold the answer is no. It's td04 vs td05 housings. I don't believe the bolt paterns are the same.
Re: (Darren 92 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darren 92 civic »</TD></TR><TR><TD CLASS="quote">friend has done it on a ls and used a sohc turbo kit</TD></TR></TABLE>
He asked if he could use the SOHC turbo on a DOHC manifold the bolt pattern for the turbo flange is not the same. It cannot be done. You can however get the SOHC manifold and modify it to fit the DOHC head. That can be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRHATCH187 »</TD></TR><TR><TD CLASS="quote">WHAT UP GUYS I HAVE A GREDDY TURBO KIT I HAVE FOR MY 99 GSR MOTOR, IN MY 92 SI, ALL I NEED IS PIPING FOR THE INTERCOOLER AND TURBO, CAN I USE THE SAME PIPES FROM A SOHC GREDDY TURBO KIT? OR DO I NEED TO BUY PIPING FOR THE MOTOR? (GSR) I FOUND SOME PIPING ON EBAY, BUT ITS FROM A SOHC! WILL THE TURBO FROM A SOHC FIT ON THE SAME MANIFOLD AS THE GSR SETUP? SUM1 HELP! </TD></TR></TABLE>
why are you yelling?
egturbo
48
01-19-2003 06:24 PM
